Emax
slider replacement
slider replacement
2012-06-08 by freddy1771994
the data and volume sliders of my emax II don't work fine anymore. Sometimes they skip parts or if I enter the lowest/highest level they jump to the opposite value. Recalibrating and cleaning did not help...
I'm wondering if these could replace them or which specifications should I keep in mind?:
http://www.musikding.de/Passive-parts/Potentiometers/Sliding-pots/Sliding-pot-60mm-10k-lin::3353.html
Is it difficult to change them or is it just desoldering the old ones replacing them by the new ones?
Thank you very much and a nice weekend!
Best regards
Freddy
Re: [emax] slider replacement
2012-06-09 by jammie
you need through hole pots they dont sell them they only do
pcb mounted with solder lugs those ones fit to slots in a pcb and mounting holes  then you use flying leads to solder to them
you need alpha pot sliders but they need to be solder through hole mounted
as long as you measure the length and the pins
best bet would be to desolder 1 the data one as you can still use the up down keys to scroll through the display
the emax1 has brand new sliders on it i will try and dig through my receipts toi find where i brought it from
  To: emax@yahoogroups.com
  Sent: Saturday, June 09, 2012 12:08 AM
  Subject: [emax] slider replacement
  Best regards
  Freddy
looking at those sliders they are through hole but weather they are the same fitting is another question
as the ones on the emaxes have through hole lugs on the external casing for solder mounting to the pcb
and the ones on that site they dont which means that the solder terminals are the machanical connection also unlike the originals as the machanical strength is the external metal case which is soldered to the pcb aswell
if i remember right there are 7 solder connection or 5 solder connections
4 machanical and 1+2 for the pot
or its 2 for machanical 1 on oposite sides and 1+2 for the pot
ask for a machanical drawing so that you can see dimensions and so you can measure for correct replacement if you cant get the metal case with solder lugs you can get some solid solder pins and solder them to the pcb and to the sides of the metal housing to give you a strong machanical connection
  Best regards
  Freddy
