quantum HD and emax 1
2002-11-13 by subruxu
Hi Today i tried to boot my emax with a quantum prodrive lps and a quantum prodrive els. They work, the els version is more quiet. Thanks to Skip.
2002-11-29 by bobking@...
<<<<:stereo ears:>>>> > Hi > > > Today i tried to boot my emax with a quantum prodrive lps and a > quantum prodrive els. > They work, the els version is more quiet. > > Thanks to Skip. > > > > > > Emax and Emax II User's Group Website > > http://www.silveriafamily.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service > <http://docs.yahoo.com/info/terms/> . > Hi I just bought a quantum prodrive lps to hook up to my emax1(with SE update) can anyone describe the procedure for installing the drive and setting it up. Thanks Bob. -- [Non-text portions of this message have been removed]
2002-11-29 by Skip Spoula
1) Is your Emax equiped with a hard drive or a SCSI port to begin with? 2) If not forget trying to install your hard drive into your Emax. 3) If it is equiped reply back and we'll go to the next step. Skip
To: emax@yahoogroups.com
Sent: Friday, November 29, 2002 10:17 AM
Subject: Re: [emax] quantum HD and emax 1
> Hi
> Thanks to Skip.
Hi
up.
Thanks
Bob.
Yahoo! Groups Sponsor
ADVERTISEMENT
[Non-text portions of this message have been removed]2003-01-09 by bobking@...
> 1) Is your Emax equiped with a hard drive or a SCSI port to begin with? > 2) If not forget trying to install your hard drive into your Emax. > 3) If it is equiped reply back and we'll go to the next step. > > Skip > > ----- Original Message ----- > From: bobking@... > To: emax@yahoogroups.com > Sent: Friday, November 29, 2002 10:17 AM > Subject: Re: [emax] quantum HD and emax 1 > > > <<<<:stereo ears:>>>> > >> > Hi >> > >> > >> > Today i tried to boot my emax with a quantum prodrive lps and a >> > quantum prodrive els. >> > They work, the els version is more quiet. >> > >> > Thanks to Skip. >> > >> > >> > >> > >> > >> > Emax and Emax II User's Group Website >> > >> > http://www.silveriafamily.com >> > >> > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service >> > <http://docs.yahoo.com/info/terms/> . >> > > Hi > > I just bought a quantum prodrive lps to hook up to my emax1(with SE update) > can anyone describe the procedure for installing the drive and setting it > up. > > Thanks > > Bob. > Hi again Skip I just got my emax back after a while and am now ready to connect up a the quantum pro drive. In answer to your question there is a SCSI connection on the emax and when I opened it up a I noticed a connecter for a 50 pin cable labeled CN2. I guess this would be for a hard disc although none is presently fitted. Regards Bob King -- [Non-text portions of this message have been removed]
2003-01-09 by Rob Keeble
Hi, The Emax 1 firmware does not support anything other than the 20MB Miniscribe 8425S and a small number of very unusual 10 - 20MB drives. The Emax will only format 20MB and 36 banks. It will work with a SCSI ZIP100 drive, although it will only format 20MB. THe ZIP is by far the best option, as is infinite. The Emax 2 firmware supports a wider range of drives, especially Quantum Prodrives as the factory was nearby.. The Emax 1 motherboards often have a 50 pin SCSI connector, but you need the SCSI chip and SCSI PAL chip and SCSI boot ROM for it to work...These parts are quite expensive, so an upgrade can cost 100-150 US dollars. Regards Rob > 1) Is your Emax equiped with a hard drive or a SCSI port to begin with? > 2) If not forget trying to install your hard drive into your Emax. > 3) If it is equiped reply back and we'll go to the next step. > > Skip > > ----- Original Message ----- > From: bobking@... > To: emax@yahoogroups.com > Sent: Friday, November 29, 2002 10:17 AM > Subject: Re: [emax] quantum HD and emax 1 > > > <<<<:stereo ears:>>>> > >> > Hi >> > >> > >> > Today i tried to boot my emax with a quantum prodrive lps and a >> > quantum prodrive els. >> > They work, the els version is more quiet. >> > >> > Thanks to Skip. >> > >> > >> > >> > >> > >> > Emax and Emax II User's Group Website >> > >> > http://www.silveriafamily.com >> > >> > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service >> > <http://docs.yahoo.com/info/terms/> . >> > > Hi > > I just bought a quantum prodrive lps to hook up to my emax1(with SE update) > can anyone describe the procedure for installing the drive and setting it > up. > > Thanks > > Bob. > Hi again Skip I just got my emax back after a while and am now ready to connect up a the quantum pro drive. In answer to your question there is a SCSI connection on the emax and when I opened it up a I noticed a connecter for a 50 pin cable labeled CN2. I guess this would be for a hard disc although none is presently fitted. Regards Bob King -- [Non-text portions of this message have been removed] Emax and Emax II User's Group Website http://www.silveriafamily.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed]
