PSU dead!
2012-07-23 by windefalk
Hi My PSU is dead, I think. Suddenly it would not start! Does anyone know if I could replace the psu on an emax 1 rack with one from an emax 1 keyboard? Regards Kalle
2012-07-23 by Ted Summers
Yes. You can also replace it with one from epr electronics or Jammie may have one, or it can also be replaced with some PC power supply, if you know how. On Mon, Jul 23, 2012 at 8:21 AM, windefalk <kalle.windefalk@...>wrote: > ** > > > Hi > > My PSU is dead, I think. Suddenly it would not start! > Does anyone know if I could replace the psu on an emax 1 rack with one > from an emax 1 keyboard? > > Regards > Kalle > > > [Non-text portions of this message have been removed]
2012-07-23 by jammie
yes you can
To: emax@yahoogroups.com
Sent: Monday, July 23, 2012 4:21 PM
Subject: [emax] PSU dead!
Hi
Kalle
[Non-text portions of this message have been removed]2012-07-23 by jammie
i have 3 spares 2 emax 1 type and 1 switchmode type as used on the later emax1,s and emax2 epr have sold out of the psu last time i checked ----- Original Message -----
From: "Ted Summers" <djtbs1@...> To: <emax@yahoogroups.com> Sent: Monday, July 23, 2012 4:43 PM Subject: Re: [emax] PSU dead! > Yes. > You can also replace it with one from epr electronics or Jammie may have > one, or it can also be replaced with some PC power supply, if you know > how. > > On Mon, Jul 23, 2012 at 8:21 AM, windefalk > <kalle.windefalk@...>wrote: > >> ** >> >> >> Hi >> >> My PSU is dead, I think. Suddenly it would not start! >> Does anyone know if I could replace the psu on an emax 1 rack with one >> from an emax 1 keyboard? >> >> Regards >> Kalle >> >> >> > > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Emax and Emax II User's Group Website > > http://www.silveriafamily.comYahoo! Groups Links > > >
2012-08-07 by windefalk
Hi Ted! Thanks. I swapped the boards to the keyboard but unfortunately the display is dead on that one :/ Maybe it's easier to replace a psu than a display? Cheers --- In emax@yahoogroups.com, "jammie" <jammie.emma@...> wrote:
> > i have 3 spares 2 emax 1 type and 1 switchmode type as used on the later > emax1,s and emax2 > > epr have sold out of the psu last time i checked > ----- Original Message ----- > From: "Ted Summers" <djtbs1@...> > To: <emax@yahoogroups.com> > Sent: Monday, July 23, 2012 4:43 PM > Subject: Re: [emax] PSU dead! > > > > Yes. > > You can also replace it with one from epr electronics or Jammie may have > > one, or it can also be replaced with some PC power supply, if you know > > how. > > > > On Mon, Jul 23, 2012 at 8:21 AM, windefalk > > <kalle.windefalk@...>wrote: > > > >> ** > >> > >> > >> Hi > >> > >> My PSU is dead, I think. Suddenly it would not start! > >> Does anyone know if I could replace the psu on an emax 1 rack with one > >> from an emax 1 keyboard? > >> > >> Regards > >> Kalle > >> > >> > >> > > > > > > [Non-text portions of this message have been removed] > > > > > > > > ------------------------------------ > > > > Emax and Emax II User's Group Website > > > > http://www.silveriafamily.comYahoo! Groups Links > > > > > > >
2012-08-08 by Ted Summers
The display should be movable from the one unit to the other- just the display itself.... Those brown connector things are push through for the Display pins... try the "dead" display in the working unit... On Aug 7, 2012, at 2:46 PM, windefalk wrote: Hi Ted! Thanks. I swapped the boards to the keyboard but unfortunately the display is dead on that one :/ Maybe it's easier to replace a psu than a display? Cheers --- In emax@yahoogroups.com, "jammie" <jammie.emma@...> wrote: > > i have 3 spares 2 emax 1 type and 1 switchmode type as used on the later > emax1,s and emax2 > > epr have sold out of the psu last time i checked > ----- Original Message ----- > From: "Ted Summers" <djtbs1@...> > To: <emax@yahoogroups.com> > Sent: Monday, July 23, 2012 4:43 PM > Subject: Re: [emax] PSU dead! > > > > Yes. > > You can also replace it with one from epr electronics or Jammie may have > > one, or it can also be replaced with some PC power supply, if you know > > how. > > > > On Mon, Jul 23, 2012 at 8:21 AM, windefalk > > <kalle.windefalk@...>wrote: > > > >> ** > >> > >> > >> Hi > >> > >> My PSU is dead, I think. Suddenly it would not start! > >> Does anyone know if I could replace the psu on an emax 1 rack with one > >> from an emax 1 keyboard? > >> > >> Regards > >> Kalle > >> > >> > >> > > > > > > [Non-text portions of this message have been removed] > > > > > > > > ------------------------------------ > > > > Emax and Emax II User's Group Website > > > > http://www.silveriafamily.comYahoo! Groups Links > > > > > > > [Non-text portions of this message have been removed]
2012-08-08 by Kalle Windefalk
Thanks Ted! 2012/8/8 Ted Summers <djtbs1@...> > The display should be movable from the one unit to the other- just the > display itself.... > Those brown connector things are push through for the Display pins... > > try the "dead" display in the working unit... > > On Aug 7, 2012, at 2:46 PM, windefalk wrote: > > Hi Ted! > > Thanks. I swapped the boards to the keyboard but unfortunately the display > is dead on that one :/ > Maybe it's easier to replace a psu than a display? > > Cheers > > --- In emax@yahoogroups.com, "jammie" <jammie.emma@...> wrote: > > > > i have 3 spares 2 emax 1 type and 1 switchmode type as used on the later > > emax1,s and emax2 > > > > epr have sold out of the psu last time i checked > > ----- Original Message ----- > > From: "Ted Summers" <djtbs1@...> > > To: <emax@yahoogroups.com> > > Sent: Monday, July 23, 2012 4:43 PM > > Subject: Re: [emax] PSU dead! > > > > > > > Yes. > > > You can also replace it with one from epr electronics or Jammie may > have > > > one, or it can also be replaced with some PC power supply, if you know > > > how. > > > > > > On Mon, Jul 23, 2012 at 8:21 AM, windefalk > > > <kalle.windefalk@...>wrote: > > > > > >> ** > > >> > > >> > > >> Hi > > >> > > >> My PSU is dead, I think. Suddenly it would not start! > > >> Does anyone know if I could replace the psu on an emax 1 rack with one > > >> from an emax 1 keyboard? > > >> > > >> Regards > > >> Kalle > > >> > > >> > > >> > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > ------------------------------------ > > > > > > Emax and Emax II User's Group Website > > > > > > http://www.silveriafamily.comYahoo! Groups Links > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Emax and Emax II User's Group Website > > http://www.silveriafamily.comYahoo! Groups Links > > > > [Non-text portions of this message have been removed]
Hi Ted. I replaced the working display with the non-working. Strange patterns appeared when I switched on the keyboard. So I took the working display and replaced the non working. Same thing. Dead. So I figured it might be the chip. I desoldered the whole "display package" and soldered it onto the board. Same thing but the backlight works (bought a new el foil a couple of days ago). Can it be the flat cable? Regards Kalle 8 aug 2012 kl. 03:00 skrev Ted Summers <djtbs1@...>:
> The display should be movable from the one unit to the other- just the display itself.... > Those brown connector things are push through for the Display pins... > > try the "dead" display in the working unit... > > On Aug 7, 2012, at 2:46 PM, windefalk wrote: > > Hi Ted! > > Thanks. I swapped the boards to the keyboard but unfortunately the display is dead on that one :/ > Maybe it's easier to replace a psu than a display? > > Cheers > > --- In emax@yahoogroups.com, "jammie" <jammie.emma@...> wrote: >> >> i have 3 spares 2 emax 1 type and 1 switchmode type as used on the later >> emax1,s and emax2 >> >> epr have sold out of the psu last time i checked >> ----- Original Message ----- >> From: "Ted Summers" <djtbs1@...> >> To: <emax@yahoogroups.com> >> Sent: Monday, July 23, 2012 4:43 PM >> Subject: Re: [emax] PSU dead! >> >> >>> Yes. >>> You can also replace it with one from epr electronics or Jammie may have >>> one, or it can also be replaced with some PC power supply, if you know >>> how. >>> >>> On Mon, Jul 23, 2012 at 8:21 AM, windefalk >>> <kalle.windefalk@...>wrote: >>> >>>> ** >>>> >>>> >>>> Hi >>>> >>>> My PSU is dead, I think. Suddenly it would not start! >>>> Does anyone know if I could replace the psu on an emax 1 rack with one >>>> from an emax 1 keyboard? >>>> >>>> Regards >>>> Kalle >>>> >>>> >>>> >>> >>> >>> [Non-text portions of this message have been removed] >>> >>> >>> >>> ------------------------------------ >>> >>> Emax and Emax II User's Group Website >>> >>> http://www.silveriafamily.comYahoo! Groups Links >>> >>> >>> >> > > > > > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Emax and Emax II User's Group Website > > http://www.silveriafamily.comYahoo! Groups Links > > >
Hi Jammie. How do I know if it's a switchmode type or not? Med vänlig hälsning, Kalle Windefalk 23 jul 2012 kl. 17:50 skrev "jammie" <jammie.emma@...>: > i have 3 spares 2 emax 1 type and 1 switchmode type as used on the later > emax1,s and emax2 > > epr have sold out of the psu last time i checked > ----- Original Message ----- > From: "Ted Summers" <djtbs1@...> > To: <emax@yahoogroups.com> > Sent: Monday, July 23, 2012 4:43 PM > Subject: Re: [emax] PSU dead! > > > Yes. > > You can also replace it with one from epr electronics or Jammie may have > > one, or it can also be replaced with some PC power supply, if you know > > how. > > > > On Mon, Jul 23, 2012 at 8:21 AM, windefalk > > <kalle.windefalk@gmail.com>wrote: > > > >> ** > >> > >> > >> Hi > >> > >> My PSU is dead, I think. Suddenly it would not start! > >> Does anyone know if I could replace the psu on an emax 1 rack with one > >> from an emax 1 keyboard? > >> > >> Regards > >> Kalle > >> > >> > >> > > > > > > [Non-text portions of this message have been removed] > > > > > > > > ------------------------------------ > > > > Emax and Emax II User's Group Website > > > > http://www.silveriafamily.comYahoo! Groups Links > > > > > > > > [Non-text portions of this message have been removed]
2012-08-08 by jammie
switch mode has no extra spade connectors on the opposite side of the transformer
Sent: Wednesday, August 08, 2012 10:50 PM
Kalle Windefalk
> emax1,s and emax2
> > Yes.
> > how.
> >> Hi
> >> Regards
> >> Kalle
