Emax
dual voice mode
dual voice mode
2012-11-02 by krikor kouchian
Hello,
I have a question regarding the dual voice mode.
I'm on the os3.2.
I'm sending some samples via midi sample dump, some of the samplez are
stereo sample, therefore they are transmitted as two separated voices,
automaticaly assign on primary voices.
I would like to assign both sample on the same note and pan them left and
right, i thought i could do this by coying the voice from the primary of
sample one to the secondary of sample two, but it seems impossible to
assign them this way.
Anyone knows a way of achieving this?
Maybe there's another of doing this without using dual voice mode?
Best
K
http://www.krikor.fr
+33632199413
bookings:
France/Suisse/Benelux: fanyktdj@...
World: laetitia@...
Re: [emax] dual voice mode
2012-11-03 by jammie
if you do it that way you will only get 4 note poly
what i do is use the same sample for layer 1 and 2 use the sme filter settings and vca settings then only hard pan left and right if you do it this way you get full 8 note poly but if each layer has different filter and vca settings it will be treated as 2 seperate samples only giving 4 note poly
use emxp it the quickest way of doing it unless you have sounddesigner2
  To: emax@yahoogroups.com
  Sent: Friday, November 02, 2012 10:17 PM
  Subject: [emax] dual voice mode
  Hello,
  I'm on the os3.2.
  Best
  K
  +33632199413
  bookings:
  World: laetitia@...
Re: dual voice mode
2012-11-03 by krikor kouchian
Hi Jammie,
thanks, but i'm not i understand, you say you use the same sample on layer
1&2 as to creat a "fake" stereo sample, on my side i want to assign two
different samples (which were originaly a stereo sample) to the same note,
one on left and one on right.
i'm on mac so no emxp for me unfortunately�
Le samedi 3 novembre 2012, jammie <jammie.emma@...> a �crit :
note poly
> From: krikor kouchian
> Hello,
> I'm on the os3.2.
> Best
> K
> +33632199413
> bookings:
> World: laetitia@...
+33632199413
bookings:
World: laetitia@...
Re: dual voice mode
2012-11-03 by krikorola
I have an old g4 on os9 with an amIII card in the cellar, but I'm not sure it will help with sd2, right?
I checked emxp and even though it ill run on bootcamp, it doesn't recognize an external floppy drive, and the macpro can't have an internal one...
So I guess i'm stuck with the msd on dspquattro.
I still could not get the two different samples on L & R on the same note assignation though
>   ----- Original Message -----
>   Hello,
>   I'm on the os3.2.
>   Best
>   K
>   +33632199413
>   bookings:
>   World: laetitia@...
