To: emax@yahoogroups.com
Sent: Tuesday, December 04, 2012 9:35 AM
Subject: Re: [emax] Would someone kindly post a photo of the PSU connections to and HD rack?
they are the same they can only go in one way as its a keyed connector they both have the same voltages
put the big one on the left handside across 2 of the terminals and the last terminal put the small one
they can fit only one way this is so you dont plug it in backwards
Sent: Tuesday, December 04, 2012 9:00 AM
Subject: [emax] Would someone kindly post a photo of the PSU connections to and HD rack?
In my haste to get the psu to the shop to repair two cold solder points I didn't memorize two of the connections. The two connectons are tethered together. One is a 3 point female with green purple and yellow wires, and the other is a 6 point female connector that hooks up beside it. Just don't want to mix the two up, fire up the PSU and fry something.
Thanks!
Joel
