To: <emax@yahoogroups.com>
Sent: Tuesday, December 04, 2012 4:37 AM
Subject: Re: [emax] Display not working
>I don't see a fuse on these.
> If you mean the beige colored surface mount next to CP1 screened on the
> PCB - that is a capacitor going between the positive and negative.
> Mine shows 637 ohms.
> If you need / want a yellow one I can ship you one of the five I have
> left.
> Then I will hit up the wait list to sell the rest.
> Regards,
> Ted
> On Dec 3, 2012, at 4:15 PM, Chase Smith wrote:
> Thanks, ill try to reseat the chips.
> On Mon, Dec 3, 2012 6:11 PM EST Ted Summers wrote:
>>I will check that pin 2 when I get home....
>>I have no white displays left.
>>I have 5 yellow which were not paid for and no response from the people
>>who
>>reserved them.
>>Was about to start going down the waitlist.
>>Will update you in a couple of hours if this appears to be a fuse.
>>Thx,
>>Ted
>>On Mon, Dec 3, 2012 at 1:45 PM, jammie <jammie.emma@...>
>>wrote:
>>> is it the light green screen pcb i did give a warning on these the
>>> tracks
>>> bonding material is rubbish and even with the proper equipment you still
>>> can get lifted pads
>>> best thing to do with that panel is fit the oled with the other type and
>>> hard wire it you can then do surface soldering
>>> i have a spare screen pcb and its the dark green version
>>> so if you need a spare
>>> is it a black box type with 2 connections if you look really close there
>>> will be in faint red 1k1 on it
>>> were do you live uk or usa or europe
>>> as i can get the oled displays in white but they have to be hard wired
>>> if
>>> ted has no more left
>>> ----- Original Message -----
>>> From: Chase Smith
>>> To: emax@yahoogroups.com
>>> Sent: Monday, December 03, 2012 9:13 PM
>>> Thanks for the help, but I can't find it. There is something right from
>>> pin 2 that is unlabeled and has no continuity, but I'm not sure if it's
>>> a
>>> fuse.
>>> Anyway, even so, I unsoldered the display to be able to look for the
>>> fuse.
>>> I decided to just put the old display in and while soldering noticed
>>> nearly
>>> all the pads were lifted. I tried to hook it up anyway, just to see if I
>>> could get it to work and I just get one row of black boxes with a line
>>> through it and a lit enter LED.
>>> I know I can jump all the display lines and fix that, but I don't know
>>> if
>>> there's a bigger problem, which judging from the way my day is going,
>>> I'm
>>> almost certain of it.
>>> I checked continuity on the old display that's in there, every pin is
>>> connected, but when I power up the emax I get a blank screen with black
>>> boxes on the top. Seems like I just turned it into a paper weight.
>>> ________________________________
>>> From: jammie <jammie.emma@...>
>>> Sent: Monday, December 3, 2012 3:34 PM
>>> they are usually 1k1 written on them they are flat squares
>>> if you look closely they will have fuse1 written in very small writing
>>> pin 2 on the display will go to the fuse first so follow the track for
>>> pin
>>> 2
>>> From: Chase Smith
>>> Sent: Monday, December 03, 2012 7:49 PM
>>> Power supply is putting out the right voltage. It could have been the
>>> 5v.
>>> How can I find out which is the fuse on the display? Nothing is labeled
>>> as
>>> a fuse.
>>> On Mon, Dec 3, 2012 2:26 PM EST Ted Summers wrote:
>>> >The OLED doesn't use 12V at all.
>>> >Verify your power supply is outputting the correct voltages, the
>>> >investigate further like jammie said.
>>> >There is often some Surface mount fuse on lots of things.
>>> >On Mon, Dec 3, 2012 at 10:50 AM, Chase Smith <plus_321@...>
>>> >wrote:
>>> > Hi,
>>> > After frying one cf card reader, I was careful to try to measure the
>>> > voltages on the new one I was just about to put it. Probe slipped and
>>> > I
>>> > shorted the 12v to ground and now the new white OLED display is not
>>> coming
>>> > on. The emax powers up and the zip drive will run (the enter LED comes
>>> up
>>> > and stays lit), but that's it. Fuses are still fine.
>>> > Did I fry the display too?
>>> > [Non-text portions of this message have been removed]
>>> >Emax and Emax II User's Group Website
>>> >http://www.silveriafamily.comYahoo! Groups Links
