Emax
Emax II Issue
Emax II Issue
2013-02-28 by peccisteve
Hi there!
I'm having some trouble with my recently acquired Emax II Keyboard.
When powered up, LED's for Transpose, Drive Select and Dynamic Processing remain on. After a few seconds, Transpose turns off, but the two other LED's are still on and the unit doesn't completely boot. Furthermore, the LCD show no letters at all, just a black stripe on the first line.
What can I do to get the unit working again?
P.S. Here are some pictures of the Emax when powering up.
http://img4.hostingpics.net/pics/730991Picture3.jpg
http://img4.hostingpics.net/pics/139651Picture2.jpg
Re: [emax] Emax II Issue
2013-02-28 by Ted Summers
Start by reseating your ICs and the connectors to the main logic board.
On Thu, Feb 28, 2013 at 2:26 PM, peccisteve <peccisteve@...> wrote:
> Hi there!
2013-02-28 by Robert Paul
Ok, cool. One more question (well two part).
the HD's are 50 pin SCSI? just in case I need to replace it. And what is the process to flash the SE Plus OS to the HD? Can any floppy disk with the SE Plus OS format the HD?
To: emax@yahoogroups.com
Sent: Thursday, February 28, 2013 5:36 PM
Subject: Re: [emax] Emax II Issue
> Hi there!
http://www.silveriafamily.comYahoo! Groups Links
Re: Emax II Issue
2013-02-28 by rahway_exit12
Sorry about that, disregard...
>  From: Ted Summers <djtbs1@...>
> > Hi there!
yes- it is 50 pin scsi- it might not handle a drive larger than 512MB.
They came w/ 20 and 40MB drives.
most people are moving to flash media these days.
boot from floppy and format hd from the menu, which will copy the OS.
> From: Ted Summers djtbs1@...>
> On Thu, Feb 28, 2013 at 2:26 PM, peccisteve peccisteve@...> wrote:
> > Hi there!
Re: Emax II Issue
I forgot to mention I'm not into electronics at all, so I wouldn't risk myself inside the Emax... Tha would make things worse! Any idea who could help me out?
> > Hi there!
Re: Emax II Issue
2013-03-01 by cheju_99
If you don´t wanna spend money first try  reseating IC´s on a garbage circuit board. Same opinion as Ted....i had the same event on my EMax, finally resolved by this way.
good luck hunting the IC.
> > On Thu, Feb 28, 2013 at 2:26 PM, peccisteve <peccisteve@> wrote:
> > > Hi there!
