Re: [EXS] record enabling multiple exs's
2003-09-25 by Eli Krantzberg
funktronik2000 wrote: > Does anybody know if there is a way to record > enable more than one exs at a time? I am using the exs live on > my laptop to trigger samples played by my drummer. I want to > use native effects on some samples but not others yet it seems > you can only play one sampler at a time. Any ideas... Cheers, Sounds like this is a good job for the multiple outputs functionality of the EXS 24. Use your one single EXS instrument, but assignn the specific samples that you want processed to diiferent outputs other than the main 1-2 outs. You do this from within the EXS editor window. Then create some aux objects in your Logic environment and set thier inputs to correspond to the outs you assigned in the EXS editor. So now you have isolated samples arriving at these separate aux objects available for individual processing before all being routed to you main outputs. Hope this makes sense...... -- Eli Krantzberg Nightshift Orchestra / Almat Productions http://www.nightshiftorchestra.com
