"peter_baldwin10"
> why isn't this playing
> back at regular speed so I can hear it and edit it??! Many thanks,
I suspect the audio files to be at another samplerate than what you're using
in Logic.
The EXS will play back files correctly but Logic won't (and the EXS "E"
button does nothing else but load the file into Logic's Sample Edit).
I recommend converting samples to a common samplerate (44.1 or 48 kHz,
depending on what you're using in general) before you load them into the
EXS at all.
Sascha
