Syncing Samples in a Song
2004-08-28 by Pete Baldwin
I was wondering if anyone has an tricks of the trade w/regard to timing of samples within a tune. I'm having difficulty synchronizing everything. The best thing I can think of is to set a guide track in an audio track of one sample, determine the exact tempo by pressing the "T" key and then looping it. This would be the "master" loop for a particular section of a song from which other samples from the same source (sampled tune/groove), even if a little off tempo wise, can be played over (just so long as they aren't played for very much time - at which they would fall out of sync w/the master sample). If you move on to another "master" sample within the same song, you determine that sample's tempo and change the tempo in the tune to that new tempo. Does this sound right? Does anyone have any knowledge/experience to share with regard to this? Are there any good sources online to read about such things? Many thanks, Pete
