Troubles with Multi Outs in Aux
2004-09-30 by daniloballo
I recently definitely turned to G5 (Dual 2.0 , 2.5 GB Ram) and OSX (10.3), with Logic Pro. I was using a Multi-EXS Drumset Program, and when I turned my separate outs to relative aux, something strange happened... When the Drum's track is selected, all appears normal, but when I select another track... Ouch! All the instruments on Aux sounds like when your audio clock is completely out, and the sound is bit-crushed. Also, the time response of the samples is a little bit up, anticipating the beat... The sensation is that aux are excluding the Audio-card latency (MOTU 828 MKII) and playing off-sync and off-clock. When I select the Drumset Track (where there's the EXS plugIn), all sounds normally. I know for sure that in record and playback mode, the selected Instrument is processed by CPU1, and when you change the selection, the track is processed by CPU2. I'm working in "Multiprocessor mode", so I can't find a solution... Does anybody gets the same trouble? Danilo
