On Oct 17, 2004, at 22:52, Paul Stephenson wrote:
> How are you guys selecting your stop start points on your samples? I
> am
> used to using Kontakt where I can visually see the sample and then fine
> tune everything, but in EXS I only have numbers to choose from which is
> kind of a pain.
The EXS assumes that the samples have a correct starting point and the
numbers are to alter the sound for playback. There is no visual
finetuning.
If you want to tweak your own samples or duplicated (!) samples of
existing instruments, open them in the instrument editor, select a zone
and click on the small "E". That opens the sample editor.
Peter Ostry
