processing each drum hit from an exs kit when mixing?
2005-06-30 by tony vincent
after you have programmed a drum kit, how do you all process each drum in the mix stage? do you all separate the MIDI information (that goes to the exs kit), bouncing it to disc and the process each drum independently? that¹s how i¹ve done it in the past- but there really HAS to be an easier way for this.... any help is greatly appreciated. always, tv [Non-text portions of this message have been removed]
2005-06-30 by Chris Coccia
On Jun 29, 2005, at 6:41 PM, tony vincent wrote: > after you have programmed a drum kit, how do you all process each > drum in > the mix stage? do you all separate the MIDI information (that goes > to the > exs kit), bouncing it to disc and the process each drum independently? > that�s how i�ve done it in the past- but there really HAS to be an > easier > way for this.... > any help is greatly appreciated. > always, > tv > You are aware that there are not only mono and stereo Audio Units but Multi channel ones as well right? Its been this way for quite awhile now, I believe the EXS24MKii has a total of 16 individual channels to work with (could be off by a couple but think its 16) you need to make your patches Multi Channel instead of stereo and then configure your outputs in the patch accordingly.. --- Chris www.descentrecords.com [Non-text portions of this message have been removed]
2005-06-30 by Eli Krantzberg
On Jun ,29, 2005, at 9:41 PM, tony vincent wrote: > after you have programmed a drum kit, how do you all process each drum > in > the mix stage? do you all separate the MIDI information (that goes > to the > exs kit), bouncing it to disc and the process each drum independently? > that¹s how i¹ve done it in the past- but there really HAS to be an > easier > way for this.... I don't think there's any one magic soloution. But there is certainly no need to actually print each part as audio first. I usually just create multiple instances of the same EXS instrument, and then separate the midi information as needed. Sure it uses up more EXS instruments, but it doesn't really take up any significant additional system resources. You still have all the data as midi, so it is editable up to the end; and you can process the different EXS instruments as needed. I also often output them all to a bus to act as a subgroup where I can apply some general processing to all of them at once, and control the overall pre-mixed drumkit level - the best of both worlds. Alternatively you can use the multiple output/aux feature; but to tell you the truth, unless you're setting up a template for repeated use, it seems like more work to me than just splitting the midi information across several instances of the same instrument. And you don't need to deal with the latency issues of putting plugins on auxes. Yeah, yeah, I know PDC in L7.1 takes care of that. But that's also not so simple; there are other issues the full PDC option brings to the party that need to be dealt with. I prefer to just keep it ol' skool:-) -------- Eli Krantzberg http://www.nightshiftorchestra.com Almat Productions
2005-06-30 by Jasper Boeke
--- In exs-users@yahoogroups.com, Eli Krantzberg <elik@v...> wrote: > > On Jun ,29, 2005, at 9:41 PM, tony vincent wrote: > > > after you have programmed a drum kit, how do you all process each drum > > in > > the mix stage? do you all separate the MIDI information (that goes > > to the > > exs kit), bouncing it to disc and the process each drum independently? > > that¹s how i¹ve done it in the past- but there really HAS to be an > > easier > > way for this.... > > I don't think there's any one magic soloution. But there is certainly > no need to actually print each part as audio first. > > I usually just create multiple instances of the same EXS instrument, > and then separate the midi information as needed. Sure it uses up more > EXS instruments, but it doesn't really take up any significant > additional system resources. You still have all the data as midi, so it > is editable up to the end; and you can process the different EXS > instruments as needed. I also often output them all to a bus to act as > a subgroup where I can apply some general processing to all of them at > once, and control the overall pre-mixed drumkit level - the best of > both worlds. > > Alternatively you can use the multiple output/aux feature; but to tell > you the truth, unless you're setting up a template for repeated use, it > seems like more work to me than just splitting the midi information > across several instances of the same instrument. And you don't need to > deal with the latency issues of putting plugins on auxes. Yeah, yeah, I > know PDC in L7.1 takes care of that. But that's also not so simple; > there are other issues the full PDC option brings to the party that > need to be dealt with. I prefer to just keep it ol' skool:-) > > > -------- > Eli Krantzberg > http://www.nightshiftorchestra.com > Almat Productions If you do want to use the multichannel (wich is once you've done it and got used to, very time efficient), here's what you do: -Use the Exs24 multichannel plug in -in the instrument editor, add groups for the different drums: kick, snare, toms hh/ cymbals etc. Route these groups to different stereo or mono Exs outputs. (Within the "group-box") - create aux objects in the environment, and select at the input-box one of your Exs output groups. Done!
