global transpose?
global transpose?
2005-10-18 by Julie Larson
Hi everyone.
Does anyone know what would cause my entire song to be transposed 1/2
step down.  Last time I opened the song...it played fine.  I've
upgraded to 7.1.1 since then...   Every exs instrument is playing
down 1/2 step.  When I stop the song and play a note...it sounds at
the proper pitch.  I'm stumped.
Logic 7.1.1 on a G5 dual 2.7mhz 6gig ram
julie
www.julielarson.net
Re: [EXS] global transpose?
2005-10-19 by Colin Shapiro
Hi Julie,
My guess is that you opened SoundDiver. This causes the same problem
on my system every time. The only solution I've found is to do this:
Quit Logic
Open SoundDiver and do whatever you need to do.
Close SoundDiver
Log out of OSX and login again.
Restart Logic.
You songs will now play as normal.
It's a severe pain in the butt and will probably never be fixed as
no-one cares about SoundDiver anymore. If anyone has found out what
really happens in the engine, please let us know as perhaps a more
elegant solution can be devised.
Hope this fixes it....
Regards - Colin
2005-10-19 by Eli Krantzberg
On Oct ,18, 2005, at 5:22 PM, Julie Larson wrote:
> Hi everyone.
> step down.
Could be an inadvertent accident caused by playing with some of the
global track chord and/or transpose features. Check your global tracks
and make sure there is nothing there that is causing it. Because when
you adjust chord/transpose parameters there to alter Apple Loops, the
parameters end up effecting all your midi instruments.
If you are intentionally using the global tracks for this, you need to
manually check the "no transpose" feature on each midi or soft synth
track object that you don't want transposed.
Eli Krantzberg
http://www.nightshiftorchestra.com
Almat Productions
2005-10-19 by Julie Larson
On Oct 19, 2005, at 6:18 AM, Eli Krantzberg wrote:
> > Hi everyone.
> 1/2 step down.
Thanks Eli and Colin,
I checked the global tracks....nothing.  I can transpose the entire
song back up 1/2 step there...  But I'd rather it just play at pitch.
I don't think SoundDiver could have anything to do with it....I
haven't knowingly opened SoundDiver in...well...I can't remember
when.  I've got to perform this thing this weekend.  I'm trying not
to panic.
Thanks again for your help
julie
www.julielarson.net
>to panic.
Have you tried logging out and back in anyway? It could be some
system/AudioMidi quirk that gets reset when you you log out/in.
Is it only EXS instruments or all other stuff too?
The strange thing is that you get the correct pitch playing live -
same thing that happened to me. Only replaying the song causes this
half pitch lower thing.
One thing to perhaps try:
Preferences/MIDI/    click on the <Reset Messages> tab
Try checking <Pitch bend to center position> .....maybe this will help.
Don't panic....yet....   :-)
Regards - Colin
> > > Hi everyone.
> > 1/2 step down.
> tracks
Ok....when in doubt restart.  I had re-launched Logic...so it didn't
occur to me that there would be a problem...but...I restarted and the
spooks are gone.
Thanks for the help.
julie
www.julielarson.net
