editing loop points in sample editor doesn't work as expected
2006-01-10 by jurgenfrenz
I asked this a few days ago but there was no reply - perhaps I didn't explain my problem well.
Editing loop points in the sample editor (pressing the "E" button in the zone window) worked
for me a few days ago and never again. I can drag the LS and LE bars around in the sample
window but their position is not updated in the zone window - the loop points remain the
values that I typed in as numbers in the zone window.
Just what am I overlooking? Please advice...
Cheers
Re: [EXS] editing loop points in sample editor doesn't work as expected
2006-01-10 by Eli Krantzberg
> points remain the
You probably have to actually save and reload the instrument in order
for the newly edited loop parameters to be recognized.
Eli Krantzberg
http://www.nightshiftorchestra.com
Almat Productions
Re: editing loop points in sample editor doesn't work as expected
2006-01-10 by Pete Thomas
>> points remain the
I find that moving the LS and LE pointers updates the zone window info
immediately.
Pete Thomas
www.petethomas.co.uk
- Free Logic Icons, Environments and EXS Instruments
Re: [EXS] Re: editing loop points in sample editor doesn't work as expected
> immediately.
I'll take your word for it; I haven't tried it myself. Well, that rules
out that possibility then .......
Eli Krantzberg
Almat Productions
2006-01-11 by Jurgen Frenz
thank you very much for your comments.
I loaded MANY different instruments form the lib and
it works without problems. But it still does not work
with my own samples! What a drag... When I reload the
instrument the samples with their (rather bad) loop
points reolad, so there is no problem as with file
locations etc.
If any of you has time to ponder over it I could
upload the instrument with just one sample nto the
group folders.
I can only think of "wrong" file loactions, I mean the
sample is not there where both EXS and the sample
editor expect it to be. But I wouldn't know how to
heal such a mistake.
Would you have suggestions what I may try? I know,
erase the instrument, rename the samples and start
form scratch :-) I would like to do that right now,
I'd like to understand..
Cheers, best wishes from China
Jurgen
2006-01-13 by Jurgen Frenz
thanks for all your comments. Saving and reopening
didn't improve the situation... So I just erased the
instrument and started from scratch. Which was not a
big job because there were just 7 samples. And
everything was working the way it should. Don't ask
why :-) and all I really care about that it works.
Thanks again
Jurgen from Beijing/China
