sample loading time
sample loading time
2006-07-05 by forums@logic-users.org
Message posted by Sinan Bokesoy <sinan@...>:
I am facing huge sample loading times on EXS24 on my Intel mini-mac with
Logic V7.2.1 with 1GB ram and OSX10.4.7
I am using a library where the samples instruments are stored in
Library/Application Support/Logic directory and the samples are stored on a
firewire external hardisk.
The sample loading time is too long, where it is impossible to work with.
I did try the same thing/setup on my old G4 mini-mac with Logic7.2 and OSX
10.4.6. It works very fluent, the samples are loaded instantly.
So I can't see the possible solution and share please your experience if you
had similar problem.
thanks,
Sinan
Re: [EXS] sample loading time
2006-07-05 by Eli Krantzberg
> with
> [snip]
> and OSX
Is this just happening the first time you load a new instrument? Or is
it also happening even after it has already been loaded in previously?
Because on a new system, it takes time for Logic to find the associated
samples the first time it is locating them. If it is just on the
initial search/load, then EXS Manager from Redmatica will help
immensely. It links up the instruments with the associated samples in
advance, so that the first time you load them they are already "linked"
and load quickly.
If the problem is occurring even after the samples and instruments have
been linked up, then it is a different problem. Check out the speed of
your external FW drive(s). Are they daisy chained with other drives or
audio interfaces? Also, 1 GB of ram in todays world is not really a
lot. More ram would certainly help the situation - although this itself
is probably not the cause of the problem.
Eli Krantzberg
http://www.nightshiftorchestra.com
Almat Productions
Re: sample loading time
Hi again,
It is not just happening the first time I load a new instrument.
Sometimes the first two load operations seem to be normal,
but then the third one takes ages to load, although the sample sizes are fairly light.
My ex-drive is a Formac Disk 500XTR which is operating just fine (I recommend it highly)
Memory shouldnt be a problem since I try the same setup with a G4 mini-mac 512MB. EXS24 loads there
a Bosendorfer huge piano sample in 20sec. It never stucks.
One interesting things is, I dont see on the EXS24 on my intel mini-mac the sample load bar, which shows the sample
loading process. Are Logic files corrupted? I did reinstall Logic again withour uninstalling the former, but the problem remains.
Should I re-install all the system? I have installed bootcamp and Windows on the same harddisk, does this cause any conflicts for the
sample search operation?
best,
Sinan
Re: [EXS] Re: sample loading time
Sounds like this might be an Intel version specific problem/situation.
Sorry, I can't be of any help. I'm still running on a G4.
Eli Krantzberg
Almat Productions
