strange behavior....
2006-09-26 by Julie Larson
Hi All,
When I save in my current project, all the EXS instruments reload.
What is that?  Have I inadvertently done something to cause this or
is something corrupt.  It tends inhibit saving because it takes so
much time....  not good.
Also....when I open a movie the sound doesn't come with it.  I can
pull the sound in as an audio file....but that's just an extra step.
What's going on?
any clues?  Thanks
julie
www.julielarson.net
Re: [EXS] strange behavior....
2006-09-26 by Eli Krantzberg
>  What's going on?
Make sure the little volume slider in the QT window is actually up. It
seems to default to being all the way at the bottom (off) right after
being imported, under some circumstances.
Eli Krantzberg
http://www.nightshiftorchestra.com
Almat Productions
2006-09-27 by Julie Larson
> > What's going on?
> Eli Krantzberg
> Almat Productions
Thanks Eli, but there's no volume slider available on the quicktime
window.....
julie
www.julielarson.net
> Eli Krantzberg
> Almat Productions
Thanks again Eli.....I found the slider.  That was the problem.
I'm still having the problem that when I save all the instruments
reload.  I've been using Logic for years and never seen this one.  I
keep thinking that it must be a preference somewhere...  but if it
is....I can't find it.
Anyway...thanks again on the quicktime tip.
julie
www.julielarson.net
2006-09-27 by Eli Krantzberg
>  window.....
It looks like a little speaker icon, on the far left of the QT window,
right next to the "play" triangle. You have to click hold on the
speaker icon for the slider to pop up. I just loaded one and checked
and sure enough it defaulted to being all the way off.
Eli Krantzberg
Almat Productions
