String Vibrato & Crescendo
2006-10-23 by raymond
Message posted by raymond <shengxiong1018@...>:
I'm wondering that how to use the Modulation Matrix of EXS24 to produce the
Strings Vibrato and Crescendo??
Someone talk about the CC...erm..may i know what's CC??
Re: [EXS] String Vibrato & Crescendo
2006-10-24 by Ingo Debus
Am 23.10.2006 um 17:36 schrieb raymond:
> produce the
There are many ways to create vibrato and crescendo, and which is
best depends on the situation. You can use the LFO for vibrato but
this will probably sound not very realistic with string section
samples. You can try one of Logic's many modulation FX plug-ins.
Most realistic vibrato/crescendo is achieved when it's already in the
sample, but that is sometimes not desirable.
CC stands for Controller Change and is a MIDI message. You can use a
CC message either to modulate an EXS parameter (pitch for instance)
directly, or to control the amount of modulation of another
modulation source (a LFO for instance).
Ingo
Re: String Vibrato & Crescendo
2006-10-25 by raymond
Hi Ingo Debus:
Thanks for this wonderful Thread reply!!
Yup,did someone told me bout this LFO configuration to do the Vibrato and Crescendo so..but i just wondering how to do the setting??Could you please show me a sample ( which can be a Jpeg attachment or write down the setting in a text) ,so that i can base on the sample and learn from there?
Oh..i see.now i'm truely understand!!haa..
erm..but,eventhough i'm understand the term-Controller Change..i still don't have the idea to do the setting of the control so..because i'm not a keyboardist..so,really not even understand the function of it!Would you mind to give me some idea on it?or give me a step to fulfill it??
Thanks and appreciate!!
Ray
Re: [EXS] Re: String Vibrato & Crescendo
2006-10-29 by Ingo Debus
Am 25.10.2006 um 07:15 schrieb raymond:
An empty patch for the EXS already comes up with the LFO routed to
pitch (second entry in the modulation matrix). Just remove the "via
Ctrl #1" entry, play a bit with the sliders next to that entry and
hear waht happens...
I'm not a keyboardist either :-)
So what do you use as input device? If you do step-by-step
programming, you can use Logic's hyper draw feature to program CC data.
Ingo
2006-11-05 by raymond
Hi Ingo:
thanks for the idea.
I'm not Keyboardist as well..
I'm actually using the USB midi controller to play my strings session and use the step-by-step programming skill to fine tune everything!!
What you've mention is using the Hyper Draw to program the CC data..eh,something interesting!!
I may need to learn about it..do you mind to show me the step to cue my Vibrato & Crescendo strings??
I've try out the LFO routering ..but still can't get a very strong Vibrato feel...what to do on it??
2006-11-07 by Don Newmeyer
I strongly advise you NOT to try to make string vibrato this way. It will
sound very unrealistic. It is much better to get good sample libraries and
avoid any kind of artificial pitch control.
Don
> Hi Ingo:
> ________________________________________________________________________
> EXS Users Group - new web forums! http://logic-users.org/forums/EXS
> - To UNSUBSCRIBE: email exs-users-unsubscribe@yahoogroups.com
> - Search the entire archive: http://logic-users.org/forums/EXS/search
2006-11-10 by Sascha Franck
Defenitely seconded.
Yet, if you simply don't have any of these libraries, it may help a bit to
use the LFOs or whatever to add a bit of modulation.
To raymond:
>> Vibrato
What exactly are you doing?
Putting aside how natural (or unnatural, for the matter...) LFOs will sound
on natural string material, I can get the most strongest vibratos and
tremolos imaginable from the LFOs.
Do you want me to post a little sample patch, using one of the instruments
coming with Logic?
Sascha
