Stuck Notes in EXS 24 mk II
2007-02-07 by Petros Kolyvas
Message posted by Petros Kolyvas <pkolyvas@...>: Hi, I'm getting stuck notes in EXS 24 Mk II. The library in question is rather large. 6GB. My ram is rather limited. 2GB. Could this be a source of the stuck notes? It doesn't pop or click and plays beautifully but some notes are always one when I'm playing very quickly. The manufacturer of the library said they've never had this problem before and it's been around long enough that I believe them. Additionally, if I use Logic's stock Yamaha Grand piano library and play, no stuck notes. If I switch the library out for the much larger library after it's recorded, I can hear the stuck notes as they often surface as dissonance during complex passages. I'm not sure what to do. They library is being streamed off a 3 drive, SATA raid-0 array. Any input would be welcomed. All the best, Petros
