Arpegiator Issues...
2007-06-26 by Trystan
Message posted by Trystan <no_really69@...>: It's a ball-ache the way Logic incorporates some of its more useful features isnt it! It's (as usual) a workaround..but the best way i have found to use the arpegiator is to wire it directly between your 'Physical Input' and your 'Recording & Thru' components in the Clicks and Ports tab of the environment. Obviously when you have finished using it you have to take it out again and re-wire your environment as before. The one problem i encounter with this is that, whilst the arpegiator runs in tempo with logic, its note-on command is in sync with your key press so you will have to drag your resulting arpegiation into time afterwards, but a simple 'select all' and a click and drag on the first note in the matrix view will suffice for those non-divisible-by-4ths-and-6ths-notes hehe I think it's a bit silly that an arpegiator component wasn't included somehow in the effects or instrument menu as a modifier to automatically do this for you. but hey ho. hope this helps, and if someone has found an easier way to do this id love it please!
