Crossfading and Wave Mixing via LFO with EXS24
2007-12-17 by mandcmiller
Is there any way to crossfade between sample sets using an LFO? I am building layered,
electronica-based drum kits, with different treatments, and I want to use an LFO to switch
between samples sets. I also want to apply this method to do wave mixing. I know how to do
round robin, and to use the mod wheel to do switching, but I'd like to use the LFOs. I've also
tried this with Kontakt 2, but to no avail.
Matt
http://www.mimomusic.com
Re: [EXS] Crossfading and Wave Mixing via LFO with EXS24
2007-12-18 by Garth Hjelte
>building layered,
There is a difference between "switching" and "fading". The main
difference is that "switching" means that "this sample(s) are
available when you do something" whereas "fading" means "this
sample(s) sounds as you do something".
Fading is real time, whereas switching is "setup" time (if you can
call it that).
You'll notice in EXS24 that switching is quite versatile (to the
sample level), whereas fading is global, so it's much more
restrictive. Kontakt lifts those restrictions.
Is this your desire, for example:
You hit a key, and an ambulance siren, a loud buzzer, and a sinewave
are all playing at once, but you only hear the ambulence. As the LFO
plays through, the siren fades out and the buzzer fades in, and then
the buzzer fades out and the sinewave fades in, then the sincewave
fades out and the siren fades in, and on and on. Is that what you are after?
Garth Hjelte
Sampler User
2007-12-18 by mandcmiller
> Garth Hjelte
> Sampler User
Hey Garth,
Yeah, this is exactly what I'm after.
Matt
> are after?
Yeah, this is a good instance where the lack of sample-level LFO and
modulators in the EXS bites you. But you know what you could do:
Make 2 or more EXS instruments. Each instrument would have the same
LFO setup where it would mod volume and perhaps use a sawtooth wave
or similar. One instrument would have it straight, the other would
invert the modulation.
In Kontakt, this would be easy - instead of using LFO's, use Flex
Envelopes, and loop the envelopes, and you can custom-draw you fade
ins and fade outs. And you could do it with one instrument.
Garth Hjelte
Sampler User
> > are after?
Thanks, Garth - Flex Envelopes it is.
Matt
