Multi Channel Outputs with EXS
2008-02-15 by Toshi
Message posted by Toshi <theworldoftoshi@...>:
I'm new to Logic but am loving the heck out of it!!! Can someone assist me
if you load a mapped drum sample into the EXS and you want to have multi
outputs.  For Example, Kicks can be assigned to an output of channel 1 Snare
to channel 2 and so forth.  Was a little confused with the zones, groups
etc.  Maybe someone can dumb it down for me.  Love this user group board by
the way.  Keep it up!!!!!!
Toshi
Re: Multi Channel Outputs with EXS
2008-02-16 by mt100uk
> Toshi
Hi Toshi,
assuming you are running 8. Look in the exs24 editor and click on groups, the outputs are
listed in the seventh column from the left, click and hold to change.
Mike
2008-02-18 by Toshi
Mike -
Thanks so much for your help! Unfortunately I'm using 7 pro. Any ideas with that?  Thanks again!
2008-02-18 by mt100uk
> Mike -
again!
Yeah, very similar, except the edit window for exs24 isn't as friendly! You may have to go to
the groups menu and tell it to show you the group outputs (or is it the view menu, don't have
it in front of me at the mo!) other than that it should be very similar. You'll need to create
the aux output object manually and assign them to the exs24s outputs (ie new audio object
in the environment, change the Channel setting to the next free aux, and assign the in (in
the i/o box) to the right instrument no. and output) but its all definitely doable in 7.x (and all
previous vrs. that allowed multi outs.)
Mike
2008-02-20 by Toshi
Mike -
You're a Wizard!  Thanks so much for the feedback and putting me on the Yellow Brick Road.  Thanks your help!  I have reached OZ!
Many Many thanks,
Toshi
PS. I'm upgrading to 8.  Sounds like those steps are a lot less in 8 than 7.  Thanks again!
