Samplecell
Samplecell
2008-05-01 by Paul Najar
Can anyone tell me what "lm" means at the end of a Samplecell program
name?
Many thanks
Paul Najar
Jaminajar Music Production
www.jaminajar.com
Re: [EXS] Samplecell
2008-05-01 by Eli Krantzberg
Hi Paul,
I used to be a Samplecell user and loved it! You have to remember, it
was a different world back then :-) Samplers were limited in RAM and
believe it or not, Samplecell's 32 meg capabilities were quite trend
setting!
LM refers to "limited". Many samples libraries shipped with LM or
limited versions of the their instrument mappings as a memory saving
convenience. The LM (lm) versions often didn't have as many multi
samples or as many velocity layers - and so took up less ram,
allowing you to load more instruments at once. The idea was to use
them when you were only using the instruments for limited types of
parts where you didn't need the entire sample range represented in
full glorious ram hogging detail.
Enjoy! Some of those old samplecell sounds killed!!
> name?
> Many thanks
Eli Krantzberg
http://www.elikrantzberg.com
http://www.nightshiftorchestra.com
On 01/05/2008, at 10:06 PM, Eli Krantzberg wrote:
> Hi Paul,
> setting!
Thanks for the detailed information Eli. Yes I remember the SC as
well. I also have fond memories of my first sampler - an Ensoniq
Mirage ;-0. The lm is as I had suspected. By today's standards it's
not even worth converting them I reckon. Just convert the full
versions and I'm done.
Kind regards
Paul Najar
www.jaminajar.com
2008-05-02 by Eli Krantzberg
Yeah, the lm versions are an archaic relic of our shared collective
past :-)
Eli Krantzberg
my first sampler, was:Samplecell
2008-05-02 by Ingo Debus
Am 02.05.2008 um 01:59 schrieb Paul Najar:
> Mirage ;-0.
Now that's interesting: what was your first sampler?
Mine was a Roland S-330 (bought in 1988, still have it).
Ingo
