Trigger on key release - bug?
2009-01-02 by Ingo Debus
Hi all, I recently encountered something that seems like a bug to me: say you have an instrument with two (non-overlapping) zones, the first zone assigned to a group where the trigger parameter is set to key release; the second zone isn't assigned to any group. If you play a key in the second zone something strange happens: the sample is triggered on key-on as well as on key-off! If it is a looped sample with sustain set to a non-zero value the sample plays infinitely then. Double-clicking into the Input/Output area of Logic's transport bar (MIDI panic) stops the sample. However, if the second zone is assigned to another group (with trigger on key pressed) everything works as expected. Bug or very weird feature? Ingo
