EXS Instruments has become Logic document files
2009-01-12 by Henrik Andersson
Message posted by Henrik Andersson <henrik.a.tervald@...>:
Hi All,
Is there someone who could help me out?
For the second time ,and for some reason, some of my EXS Instruments has
turned into Logic document files and can not be used. It seems to occurs for
those instruments that has been recently used. As I have back it all up I
could mend it but it's pretty irritaing and time consuming.
Has someone else ran into this?
What I'm I doing wrong?
Please help me out
/AT
Re: [EXS] EXS Instruments has become Logic document files
2009-01-12 by Sascha Franck
How and where have they turned into Logic documents? In Finder? That
would be pretty much irrelevant as they can't be loaded from there
anyway. Or don't they just show up in the EXS anymore?
- Sascha
2009-01-12 by Colin Shapiro
>Hi All,
>Please help me out
I don't think you're doing anything wrong at all.
This has happened to me too, with just a few odd files - also
happened the other way round where Logic songs became a different
file type. Computers do not work perfectly all the time!  :-(
You could do a few things:
1 - Restore from backup
2 - Change the file extensions back to .exs (assuming they are now different)
       You can do this one by one or use a batch file-type converter
app (like xFiles)
Also, report this to Apple - maybe they can fix it in a new version
of Logic. (What version are you using by the way?)
Regards - Colin
Re: EXS Instruments has become Logic document files
Thank you Colin,
I Use Logic 7 and Logic 8.0.2
The first time it happened was in Logic 7 and today it was on Logic 8
Best
henrik Andersson-Tervald
Re: [EXS] Re: EXS Instruments has become Logic document files
2009-01-13 by Sascha Franck
> They don't show up in Logic anymore.
Ouch! That's pretty bad.
So, are the file extensions renamed indeed?
If so, try renaming them back (just a few for a start, to see whether it
helps, after that you may want to use a batch renamer, there's some free
ones around).
Also, in case this doesn't help, when have you been running some system
maintainance tools for the last time? OSX is really bad in some terms,
especially when it comes to things such as disk permissions (this hasn't
changed for one bit with OSX.5 and the sub-updates). I cannot recommend
Onyx too much, it's absolutely excellent for all these maintainance
jobs, I just fixed a friends machine in about no time, it suffered from
several issues pretty much related to what you experience right now
(missing EXS and Ultrabeat patches, missing samples, weird error
messages). Onyx is free:
http://www.titanium.free.fr/pgs/english.html
In case you're scared of running it, I can almost assure you that it
won't do any harm to your machine as long as you stick with the default
settings. I've been using it sucessfully on some machines. Really one of
the best system maintainance tools I ever used (including those for both
OSX and Windows).
Good luck,
Sascha
2009-01-13 by Renger Koning
I noticed that 'old' Logic files don't need the .exs extension (and
pre OSX 10.4 neither)
With the latest Logic * and OSC 10.5 every exs instrument file has to
have the .exs extemsion.
cheers,
Renger
2009-01-13 by Joe Albano
>>  Some of my EXS Instruments have turned into Logic document files and
>>  can not be used.. ..Has someone else ran into this?
>  Change the file extensions back to .exs (assuming they are now different)..
>  You can do this 1 by 1 or use a batch file-type converter app (like xFiles)
>  So, are the file extensions renamed indeed? If so, try renaming
>them back.. > You may want to use a batch renamer, there's some free
>ones around)..
Hi Henrick -
Colin and Sascha are right, I've seen this occasionally too - the
extensions are missing, and the files are sometimes tagged as Unix
Executables. Usually the files themselves are fine - just change the
extensions (or restore them if they're missing) back to .exs and the
files should regain the proper icon and be usable again by Logic/EXS
(you'll have to restart Logic or refresh the EXS Instrument menu,
however).
This has happened to me when the files were restored by some server
backup software, but I've seen it in other cases too.. Sascha is
right, OSX is kind of a pain in the ass with this sort of stuff
sometimes, not to mention the whole Logic long-name-short-name
nonsense..
Cheers, Joe Albano
ROOFTOP PRODUCTIONS NYC NY
Music Production  : http://www.rooftopproductions.com
Freelance/Consult : http://www.rooftopproductions.com/Consulting.html
