how do I load an EXS in EXSP24 ?
2010-08-09 by yellow_electricstar
Hello I'm a newbe at EXSP24 I installed the VST in Sonar 8 and I have some EXS smaples I'd like to use The samples consist of an ESX file plus the .wav files If I undertand well, this plugin should automatically load the sounds in the property window without having to browse the disk But I still don't understand in which directory I should put the EXS files. I have a general VSTPlugins directory and under this I have the ESXP24 directory that is: program files\VSTPlugins\EXSP24\ I noticed that under this, 3 other directories has bees created by the installation program named respectively: EXSamples Sampler Instruments SoundFont Samples I tried to put my dir with EXS and wav files under EXSamples dir and also under Sampler instruments dir but when I insert the soft synth the samples do not appear in the property window so where and how should I exactly accommodate my EXS FIles? Thanks for any help Max
