Re: [exs] EXS - latency while playing sampler from MIDI keyboard
2002-01-16 by StudioTM
Hi...I'm no expert on this.......! Yes this is a common thing. The latency is a combination of driversettings on your soundcard and settings in Logic. Are you using ASIO driver for your card? I use a LX6 Aardvark card & asio and I can reduce latency while tweeking ASIO buffer size on the soundcards controlpanel. 4ms is the lowest I can get when playing EXS directly from my masterkeyboard. Best thing to do is, record midi with the sound from your keyboard. Then connect the miditrack to EXS when playback in Logic. Thor Mamen "Hey, I'm playing a Yamaha midi keyboard through my mixer using a GINA audio card. I get a slight delay as I play the EXS24. I press the note on the keyboard and I hear the note come in slightly late. I'm sure this is a common thing but I'm new to midi. Does anyone know how I can cut down on that delay? Is there a way to optimize the settings for the GINA card? Could it be my keyboard isn't good enough to use as a MIDI controller?" (It's a cheap Yamaha PSR 262) Thanks, Joe To unsubscribe from this group, send an email to: exs-users-unsubscribe@egroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed]
