Lost audio files
2002-06-23 by kgheysen
The audio files of my Sampler instruments seem to get lost,
which makes it impossible to play them.
Example: I select the sound "bottle swing" from the "vibottle"
map of an Sample Instrument in the flip menu, called "Worlddance".
As soon as i try to select that sound i get the following error
message: EXS24 insrument "bottle swing.exs"
Audiofile Reggae BO L wav" not found
Then "continue" pops up, which i click then that very same
sample appears in the flip menu, but, as you might expect:
no sounds come out.
This "Worlddance" SI is a converted Akai format sample CDrom.
I converted the entire cd at once. Most of it's sounds play
back, about a quarter don't, as mentioned above.
I checked out properties of wav files that do play back to others
who don't, i didn't notice anything different:ie, they're all
physically in my computer, no empty files.
The files that don't play back are the last one in line in the SI
flip menu. The first 75% that do play back are in front.
PS: I still got 6 GB HD left!
