New Patch
2002-07-18 by Sascha Franck
http://www.saschafranck.de/exs/SF_FatES2_01.zip Contains two patches, one "standard" comping patch and one detuned pad, both using the same samples. The source file was some relatively simple but rather fat sounding ES2 patch. Obviously the EXS uses up way less CPU power. By default the filter is switched off, but I allready adjusted it a bit, so check it out (also use the MOD-wheel). The pad patch however starts using quite some CPU if you switch it on (has doubled zones). Btw, does someone know of a VERY simple webpage editor? Something like netscape composer with additional frame support would be pretty much sufficient for me (I don't plan becoming a web designer). In any case it should be WYSIWYG and it should not cost much (if anything at all). I want to update that EXS site... Cheers, Sascha
