Re: [exs] Vsti automation record on LA 4.8
2002-08-07 by Eli Krantzberg
delfinx2000 wrote: > Hi to all, > I tink this question its for the EXS24 too, but Im interested in the > ES1. > I am looking for the way to take a snapshot of all settings of a > preset on my > Es1 and putting them ( record) on a midi track , as the deafult > settings. > Something like > the "insert instrument midi settings as event" comand, but with > all > the settings > of the Es1 preset. > If i record, later, any filter setting chage,I think, it would be a > easy way to return > to the original preset. > Any help wil be apreciated. There's no real clear and easy way to do this. On one hand, you could easily save all your settings as a preset and simply recall it from the flip menu. But there is no way to automate this sort of "settings chage". It could be a useful feature for the soft instruments to have I suppose. On the other hand, yhou could write to automation every single parameter you want to be able to recall, and then insert these settings in your automation track along the timeline where you want them. But it would be very cumbersome to have to do "all" the possible settings. And if you want to do it snapshot style, you'd probably be better off doing it the old fashioned automation way; with a channel splitter object with the data contained in a short sequence which you could freely place anywhere you need to. You're probably not going to automate and change _every_ setting; so just automate the parameters you are going to be changing in real time. I doubt there would be more than a handful on any given instrument. -- Eli Krantzberg Nightshift Orchestra / Almat Productions http://www.nightshiftorchestra.com
