There are several schools of thought about oboe as far as
sound goes.
A great deal of this goes into the reeds they make..etc.
The basic split in the oboe world as far as sound goes are
1) more "buzzy" that gives it more "presence". (more pointed but
not "round" center to tone. (baroque instruments tend to be like
this...as are early string instruments)
2) center of tone more on top...thinner..more cutting
3) center of tone more middle ..darker..smoother (can have wider
center and more volume with harder reed..or..more pointed but
still round center)
4)center of tone much wider...(which is what you are hearing in
the VSL...using a very hard, stiff reed that gives a loud more
spread out sound. (more common in Europe than here)
You can hear examples of these types of oboe playing thruout
the US orchestras...but I think the main school of thought here
would probably be that most oboists here strive for more pointed
"center" to the sound..with the largest variables being whether
that center is more in the middle and slightly larger..to a smaller
more cutting center on top..as opposed to volume or loudness to
the sound of the instrument via a very hard stiff reed.
The very wide spread out sound..is not as common here in the
states..but there are some people who play this way.
These schools of thought revolve around what makes the
instrument "project" more....thinner more pointed sound? Or, a
larger middle center? And, which one of these sounds best
exemplifies the character of the oboe and the parts for which it
was written as played along with the other instrument timbres.
Players who follow one school or another (and in between) tend
to have very strong opinions about which one is better. (even for
specific styles of music).
My wife plays oboe, english horn. I had her listen to the VSL
oboe samples. She thought it was quite amazing that samples
could sound so good (she's used to hearing my kurz and a
couple of small Miroslav mini oboe samples). But, the first thing
she said was...wow..that's a hard reed. The hard reed...can be
more "open" at the tip (between the 2 reed ends)...and it vibrates
harder..which gives you that very wide, loud, spread out
sound...much like a clarinet in timbre. Speaking of which...if you
listen to the clarinet samples..you'll hear the same thing (hard
reed, big sound thats very wide).
She personally doesn't care for that type of oboe sound, but that
doesn't mean it sounds bad. On the contrary, she thought it
sounded quite good (or I should say that it was reproduced
accurately). She mentioned that this kind of sound blends very
well (but can tend to get lost). She said that the hard reed can
produce a lot of volume out of the instrument but that because
the tonal center is so spread out and wide ..that it still tends to
get lost..or be rather, non descript from the back of a concert
hall. It's not just dark, its very .."non pointed" which they try to
make up for with volume.
It's just a different school of thought about how the instrument is
played and the approach to playing it.
I understand that VSL is going to be adding more/different oboe
samples in the future. I think this is a great way to do it.
From my wifes perspective, she thinks they are GREAT
samples. What you are hearing is not something wrong with the
samples..but an accurate reproduction of "one" school of
thought about oboe sound (more common to European
orchestras..but not without it's proponents here in the states). My
wife thought they did it perfectly for this style of oboe playing. But,
we too look forward to some examples of the "other" styles of
playing as we have no doubt that they too will be done very, very
well as these have.
--- In exs-users@yahoogroups.com, Edmund Eagan <ed@t...>
wrote:
> On Monday, February 10, 2003, at 06:40 PM, Bill Canty wrote:
> > Maybe that explains why the Vienna Symphonic solo oboe
demo doesn't
> > sound as "nasal" as I've come to expect an oboe to sound...?
> Probably the Vienna has a darker, Germanic sound rather than
> brighter nasal quality you would hear from a French player.
> Edmund Eagan
> www.twelfthroot.com
