ALL OF MY SOUNDS sound REALLY High pitched!
2003-02-12 by truthhorse <bryan@truthhorse.com>
Hello out there,
I am fairly new to all of this MIDI stuff but I've been having a lot of fun with the
EXS24 and the ES2 on my Logic Platinum 5.5 in OSX.  Until today that is!  I
opened up Logic today and all of my audio files sound normal but every time I
play a note on the MIDI keyboard (no matter what instrument) it plays as if it's
20 octaves too high!  I tried lowering the octave on the keyboard but it doesn't
respond.  I tried restarting the computer but that didn't do anything!
Has anyone run into this before?  I am in a really bad position right now
because I have a lot of compositions due at the end of the week and I'm really
stuck!  Please give me some advice.
Bryan.
Re: [exs] ALL OF MY SOUNDS sound REALLY High pitched!
2003-02-12 by Hendrik Jan Veenstra
>of fun with the EXS24 and the ES2 on my Logic Platinum 5.5 in OSX.
>Until today that is!  I opened up Logic today and all of my audio
>files sound normal but every time I play a note on the MIDI keyboard
>(no matter what instrument) it plays as if it's 20 octaves too high!
>I tried lowering the octave on the keyboard but it doesn't respond.
Sounds like a problem with your keybaord maybe.  Try this: in the
environment's Clicks & Ports latyer, create a Monitor object.  Cable
the Physical Input object's SUM outlet into the Monitor (click-hold
on the little triangle after SUM and drag until the Monitor object
lights up), and cable the Monitor into the "to Sequencer" object
(sometimes called "to Rec & Thru").
Now play a middle-C on your keyboard.  If all is well, the Monitor
will show a C3 or C4 or something like that being played.  If it
shows something ridiculously high, like a C7, your keyboard is at
fault.  If the Monitor shows the right note however, but the sound is
still too high, you at least know it's not the keyboard but a
software problem.
Hendrik Jan Veenstra  <h@...>
Omega Art: http://www.omega-art.com
