On a fine day, 09-05-2003, Gilles Ruppert wrote:
>On 9/5/03 8:38, "Hans Hafner" <hanshafner@...> wrote:
>> I setting up an environment object where I can control the EXS'
>> filter cutoff with the mod wheel and the resonance with the pitch
>> wheel.
>> It works very well with the mod wheel (the transformer just
>> translates as it should) but on the pitch wheel it doesn't do
>> anything. The input of the pitch wheel shows in the monitor as
>> Channel 1 Control 0 and the value, but when I set the transformer to
> > react to this, it doesn't do anything.
> I'm not an expert on the envirnment, but AFAIK, the Pitch wheel is not a
>controller message so maybe it's not workin because of that?!?
>Don't know what a solution could be though...
Cable from the EXS channel strip into a Monitor object, move the EXS
resonance and notice the Monitor. It should show something like "F 2
xx yy" where "xx" is the Fader Event number. Delete the Monitor.
Now have the transformer's Conditions part set to
Status = Pitchbend
<leave the rest alone>
Set Operations to:
Status = Fader
Cha fix 2
-1- fix xx (i.e. the same 'xx' as above)
-2- Thru
Set the top popup to "Track Automation Splitter"
Cable from Physical Input SUM outlet into transformer.
Cable 1st outlet of transformer into the EXS channel strip directly
and cable the 2nd outlet into the To Sequencer object.
P.S. you might be interested in my UltraTrans patch, if you're
getting into mappings like this... See my website's Logic section.
Hendrik Jan Veenstra <h@...>
Omega Art: http://www.omega-art.com/
