Chromatic Mapping with numbered files
2003-06-02 by Hans Hafner
Hi there,
Is anyone else a little bit put off with the following:
I have several audio files that are consecutively numbered and I wish
to auto map those
Then the EXS just randomly throws those in any order it likes instead
of starting at C1 with file xxxx 1
Is there any way around this except naming the files with the
corresponding keynotes? That would be rather a pain since I have to
do it by hand or does anyone know a good trick of doing this with
File Buddy? The thing with File Buddy is, that if you name
alphabetically it doesn't go back to A once it hit the G and that is
kind of vital to the whole thing :-)
Thanks for the help
Cheers
Hans
Re: [EXS] Chromatic Mapping with numbered files
2003-06-02 by Hendrik Jan Veenstra
>to auto map those
File Buddy can't do this.  It would be relatively easy to write an
Applescript that does this though.  What is the exact format of the
source & target filenames?
I.e. something like:
source = name + space + number + ".aif", and target = name + space +
note/octave + ".aif", turning "viola 12.aif" into "viola B2.aif" for
example.  Naming should start with file number 1 = C1.
If you can provide such a template (if the source names follow such a
template at all, which I hope for you), then I might be able to come
up with a script that does the renaming.
Hendrik Jan Veenstra  <h@...>
Omega Art: http://www.omega-art.com/
I don't have a specific template unfortunately...
but: if you write the script so it replaces a certain string in the
name (lets take xnnn, where x is something that has to be there for
the script to recognize that it should change from this point on, and
nnn is the number that then gets translated to the keys from C1 up)
then it should work for any filename, shouldn't it?
I think this would be a very helpful utility! Thank you so much for
suggesting this.
Cheers
Hans
Hmm... not sure...  Don't all files happen to end the same way?  Like
<text><number> followed by ".aif" or something?
Of course the script could also be written such that it simply
appends 'C1' and the like to the end of the filename.  Would that
suffice?  This would potentially give files like "trumpet 1.aifC1"
though...
>suggesting this.
No problem...  How about sending me a (part of) the directory listing
of your files in private mail (plain text preferred) -- take some
random samples from a couple of folders, so that I can see if I can
find any system in the names that would be useable.
I think it could be done this way:
I use File Buddy to replace ".aif" with let's say "XZ.aif" so we end
up with a file named "something 001 XZ.aif"
Then you can have the script to find replace XZ with the note that
corresponds to 001 (C1)
But maybe I'm way off here too... I will try and find one of the
folders and mail it to you.
Thanks so much for the effort!
Cheers
Hans
