Re: [EXS] Re:Saving in Song Folder
2003-06-17 by Gilles Ruppert
> I open the EXS , hit edit and save the Instrument via the Editor > (File>Copy > Samples) in a Subfolder of my Songs Folder called Sampler Instruments. > Logic creates another Subfolder called Sampler Instruments in this > Folder, > as well as a Folder for the Samples of the Instrument. > I do this for every Instance of EXS, this might be some Work, but this > way I > can be shure, to have all needed Instruments and their Samples. > > I once tried the Option "Save used Instruments", but logic started to > copy > my whole Library to the Song-folder (v5.1if I remember correctly) - > never > tried, if it works in 6 - the method mentioned above certainly does!! > well one great thing about version 6 is the project manager: at the end of the project, just go file > save as project & then you can select whether you want to move or copy samples, audio files, etc. Very neat & tidy ;-)) Cheers, Gilles __ Gilles Ruppert Sound Engineer gilles@... Powerbook G4 15" 1GHz 1GB RAM MOTU 896 / MOTU MTP AV MBox PT 5.2 / LAP 6.1 Oxygen 8 / SAC 2k [Non-text portions of this message have been removed]
