Splitting CDDA files
2003-07-08 by damnyvenus
Guys,is there any techniques taht u use for manage CDDA format Sample CD? Someone told me to try Translator,i have CHickensys Translator 2.5 and it seems i can't find any option to split files when converting. Please any help !
2003-07-08 by Garth Hjelte
At 09:06 AM 7/8/03 +0000, you wrote: >Guys,is there any techniques taht u use for manage CDDA format Sample >CD? >Someone told me to try Translator,i have CHickensys Translator 2.5 >and it seems i can't find any option to split files when converting. >Please any help ! It's under Single Sample Mapping under Options, Split Samples When Exporting. (It's up to v2.9 now, try updating, perhaps you don't see this feature because of that.) What this does is when you convert a folder of .wav or AIFF files to EXS, it takes the Threshold (to determine what "silence" is) parameter and the Time (amount of time of silence to qualify) parameter to determine where the data slices occur. It then treats those slices as separate pieces of data and splits them into separate .wav files. I just took a CD Audio which had on the average 5 samples per track (about 500 samples total), ripped it into 99 .wav files (001.wav, 002.wav, etc.), and took that folder and converted it into EXS. The resulting .exs files referenced newly created files - 001 01.wav, 001 02.wav... which represent the slices. This all took about 3 minutes. There's other utilities that do this, even within Logic, but this is nice because it does it on the fly and makes the EXS file and references it all in one operation. Garth Hjelte Sampler User
--- In exs-users@yahoogroups.com, Garth Hjelte <garth@c...> wrote: > At 09:06 AM 7/8/03 +0000, you wrote: > > >Guys,is there any techniques taht u use for manage CDDA format Sample > >CD? > >Someone told me to try Translator,i have CHickensys Translator 2.5 > >and it seems i can't find any option to split files when converting. > >Please any help ! > > It's under Single Sample Mapping under Options, Split Samples When > Exporting. (It's up to v2.9 now, try updating, perhaps you don't see this > feature because of that.) > > What this does is when you convert a folder of .wav or AIFF files to EXS, > it takes the Threshold (to determine what "silence" is) parameter and the > Time (amount of time of silence to qualify) parameter to determine where > the data slices occur. It then treats those slices as separate pieces of > data and splits them into separate .wav files. > > I just took a CD Audio which had on the average 5 samples per track (about > 500 samples total), ripped it into 99 .wav files (001.wav, 002.wav, etc.), > and took that folder and converted it into EXS. The resulting .exs files > referenced newly created files - 001 01.wav, 001 02.wav... which represent > the slices. This all took about 3 minutes. > > There's other utilities that do this, even within Logic, but this is nice > because it does it on the fly and makes the EXS file and references it all > in one operation. > > Garth Hjelte > Sampler User Man iam exosted,i have updated Translator,have a folder with 96 long tracks *.01 02 03 etc I checked Split Samples in Export Right clicked on the folder with those wavs and told him to convert to EXS,wav What he does its create only EXS files,no wav spliting. I don't know whats wrong...
At 04:26 PM 7/8/03 +0000, you wrote: >Man iam exosted,i have updated Translator,have a folder with 96 long >tracks *.01 02 03 etc >I checked Split Samples in Export >Right clicked on the folder with those wavs and told him to convert >to EXS,wav >What he does its create only EXS files,no wav spliting. >I don't know whats wrong... Give us a call, see the phone numbers on your docs. Or email us if that's not possible. Send us a .wav file if able as well. It's likely your threshold and time settings. And, see other post. Garth Hjelte Sampler User
