Re: [EXS] G5 incompatibility -- nothing new
2003-08-21 by Nick Batzdorf
>I think you may find as well that if you buy a magma expansion chassis for
>your G5, it will support the 5v required for older PCI cards such as digi and
>motu ones. I'd double check with Magma before splashing cash, but I believe
>this to be the case. A lot cheaper than a whole new PT rig!
It's only the older, lowest-end, or totally outdated cards that won't
work; the only current one is the MIX I/O, which you may as well
replace with a MIX Farm card rather than a chassis.
To me, EXPENSion chassis only make sense if you want to add more DSP
cards to a Pro Tools rig. It would be silly to spend $1200 just too
run a PTIII PCI card or something like that.
Now, if you're running a MOTU system it could be a nuisance, because
the PCI-424 cards that work in G5s aren't available separately and
the regular PCI-424 and PCI-324 cards won't work in them.
Nick Batzdorf
818/905-9101, cell 590-9101, fax 905-5434
2003-08-21 by Dave Peverley
To: <exs-users@yahoogroups.com>
True....
I believe that MOTU are running an upgrade programme now if you dig around
motu.com - If you have a PCI-424 they'll swap it for a compatible one for
around 79USD IIRC. Peeps with PCI-324's are stuffed outa sight however :-(
~Pev
