Korg Poly800/EX800 Users group photo
Frozen Poly 800
Frozen Poly 800
2013-01-20 by cc0919ship
Hello all,
I'm wondering if you can help me out. I recently acquired a broken Poly 800 (original, not MKII.) It powers up, but immediately after powering up, the screen reads "1.8 50 01." Buttons on the front panel do nothing, and keys do not make noise. If I turn up the volume the whole way, I can hear the filter sweeping up and down. Here's where it gets interesting - I plugged in a MIDI keyboard, and when I play notes with the MIDI keyboard, the 800 makes static noises, and the last value on the screen increments by one.
I opened it up, checked the tactile switches (all seem fine.) I also replaced the internal CMOS battery. I was under the impression that MKI 800s didn't have this, so the main board may have been replaced by someone along the line.
Anyway, has anyone had a problem like this and could help me out? It is potentially one of the ICs, but I have no idea how to test them.
Christian
RE: [korgpolyex] Frozen Poly 800
2013-01-20 by backshall1
That sound like the sequencer "enable" switch is on, plus you have no
patches in memory. The sequencer switch on the back should be set to
"disable" unless you are recording a sequence. Since this is an original
Poly 800, there are several versions, some with a CR2032 lithium cell inside
to hold the sound patches in memory when it is turned off, and some without.
Since you just changed the battery, the memory will be empty or really
random.
1) Make sure the sequencer is switched to disable.
2) You need to reload the factory patches or program one of your own for
testing purposes.
If you've never loaded a patch audio file (.wav) on the "Tape In" jack of an
early 80's synth, you may want to start by just programming one of your own.
Unfortunately there are 50 parameters and you need to make sure all of them
are set at something reasonable to get a sound. You might start by setting
the Attack, Decay and Release to 0 and the Break P, Sustain to maximum (31)
for Deg1, Deg2 and Deg3. I don't think the Slope matters when set this way.
If you hear noise, then alter parameter 33 (Noise level) to see if it makes
a difference. Oh, and parameter 41 (Cutoff) should be turned up full during
this testing.
If the sequencer switch is really the main problem, then you should be able
to get some sound out of it and we can help you get the factory patches
loaded if you need help.
Don Backshall
  _____
From: korgpolyex@yahoogroups.com [mailto:korgpolyex@yahoogroups.com] On
Behalf Of cc0919ship
Sent: Saturday, January 19, 2013 9:32 PM
To: korgpolyex@yahoogroups.com
Subject: [korgpolyex] Frozen Poly 800
Hello all,
the line.
Christian
Re: Frozen Poly 800
Thanks for the suggestions. I took a look, sequencer was disabled. Perhaps the switch is bad? I'm not sure how to test it, it has 4 main pins, then 14 smaller pins. I'm using a multimeter, but can't figure out what pins the switch is effecting.
> random.
> testing purposes.
> this testing.
> Don Backshall
>   _____
> Hello all,
> the line.
> Thanks,
> Christian
RE: [korgpolyex] Re: Frozen Poly 800
The four "main" pins are nothing. They just ground the outer metal shell of
the switch and keep it securely on the board. There are only two pins that
matter, and you can see which two they are by looking at which pins actually
have something connected to them. When enabled, these two pins are shorted
together ( less than 0.5 ohms with an ohmmeter). When disabled, they are not
connected to each other (greater than 10 Meg ohms between them).
Don B.
  _____
Sent: Saturday, January 19, 2013 10:51 PM
Subject: [korgpolyex] Re: Frozen Poly 800
--- In korgpolyex@yahoogroups.com <mailto:korgpolyex%40yahoogroups.com> ,
inside
without.
> random.
> testing purposes.
an
own.
them
(31)
way.
makes
during
> this testing.
able
> Don Backshall
> _____
> From: korgpolyex@yahoogroups.com <mailto:korgpolyex%40yahoogroups.com>
[mailto:korgpolyex@yahoogroups.com <mailto:korgpolyex%40yahoogroups.com> ]
On
> To: korgpolyex@yahoogroups.com <mailto:korgpolyex%40yahoogroups.com>
> Hello all,
800
do
filter
MIDI
static
800s
along
> the line.
> Thanks,
> Christian
Re: Frozen Poly 800
Thanks. The switch appears to be working normally.
> Don B.
>   _____
> --- In korgpolyex@yahoogroups.com  ,
> inside
> without.
> > random.
> > testing purposes.
> an
> own.
> them
> (31)
> way.
> makes
> during
> > this testing.
> able
> > Don Backshall
> > _____
> [mailto:korgpolyex@yahoogroups.com  ]
> On
> > Hello all,
> 800
> do
> filter
> MIDI
> static
> 800s
> along
> > the line.
> > Thanks,
> > Christian
Re: Frozen Poly 800
Any other ideas?
> > Don B.
> >   _____
> > inside
> > without.
> > > random.
> > > testing purposes.
> > an
> > own.
> > them
> > (31)
> > way.
> > makes
> > during
> > > this testing.
> > able
> > > Don Backshall
> > > _____
> > On
> > > Hello all,
> > 800
> > do
> > filter
> > MIDI
> > static
> > 800s
> > along
> > > the line.
> > > Thanks,
> > > Christian
Re: Frozen Poly 800
2013-01-24 by cc0919ship
Anyone else have any ideas? I really don't want to trash this synth if it is something simple, was really looking forward to using it :(
> Hello all,
> Thanks,
> Christian
Re: [korgpolyex] Re: Frozen Poly 800
2013-01-24 by Michael Hawkins
Since the switch checked out OK, you would have to look further into the electronics that runs the scanning of the switches.
What you should do is start from the bottom note on the keyboard and work your way up through all of the keys, normals and accidentals. Take note of which keys do NOT cause the display to count up (the right hand displays should increment by 1 each time to play a note).
If some of the notes on the keyboard do NOT cause the display to increment then we can check the schematic and see if we can work out which chips or DTC's or diodes or other things might be broken.
Mike
Sent: Wednesday, January 23, 2013 8:36 PM
--- In korgpolyex@...m, "cc0919ship"  wrote:
> Hello all,
> Thanks,
> Christian
Re: Frozen Poly 800
Hey Michael,
Thanks so much for the response! I plugged in my 88 key MIDI controller, and every key (including accidentals) incremented the value by 1.
> Mike
>  From: cc0919ship
> Â
> > Hello all,
> > Thanks,
> > Christian
2013-01-24 by Martin Ator
Was the battery in a battery holder, or did the battery have tabs attached to it that were soldered to the circuit board?(I'm guessing it was in a battery holder if you were able to change it)
Did you buy it not working, how many volts was the original battery, did it need changing?
Is everything the same as before you changed the battery?
Re: Frozen Poly 800
Hello Martin,
Battery just had tabs. Functioning exactly the same as before I replaced it.
2013-01-24 by backshall1
When you first turn the Poly-800 on, with sequencer disabled, the display should say 11 .P (only two sets of digits). The only time you should see three sets of digits which increment when you press a key is if the sequencer is enabled AND the Start button has been pressed. Do you see any change in the display if you press the Prog/Para button a couple of times? Do you see any change in the display if you move the Tape switch between Disable/Enable? It should say 7APE when it is enabled.
Don B.
From: korgpolyex@yahoogroups.com [mailto:korgpolyex@yahoogroups.com] On Behalf Of cc0919ship
Sent: Wednesday, January 23, 2013 11:20 PM
Hey Michael,
> Mike
> From: cc0919ship
> Â
> > Hello all,
> > Thanks,
> > Christian
Re: Frozen Poly 800
Hm...Don, no matter what switches are enabled or disabled, and no matter what buttons on the front panel are pressed (or how many times) the display stays at 1.8 50 01 (unless I use the MIDI keyboard.) I'll try again with the Tape switch, but I'm almost positive that any change in switches doesn't yield any sort of result. I've definitely never seen it say 11 .P, no matter what I did (although I think that once I hit keys on the MIDI keyboard enough, it did change to 1.8 .P once.
> Don B.
>   _____
> Hey Michael,
> > Mike
> > From: cc0919ship
> > Â
> "cc0919ship" wrote:
> > > Hello all,
> one.
> the line.
> > > Thanks,
> > > Christian
Have you opened up the Poly and had a look to see if there is any sign of brown sludge that might have come from old batteries in the battery compartment? Let's exclude that first.
Then, do you have a multimeter and soldering iron etc?
Mike
Sent: Thursday, January 24, 2013 9:14 AM
> Don B.
>   _____
> Hey Michael,
> > Mike
> > From: cc0919ship
> > Â
> "cc0919ship" wrote:
> > > Hello all,
> one.
> the line.
> > > Thanks,
> > > Christian
Re: Frozen Poly 800
I have, no signs of corrosion. The guts look in pristine order. I do have both.
Christian
> Mike
>  From: cc0919ship
> Â
> > Don B.
> >   _____
> > Hey Michael,
> > > Mike
> > > From: cc0919ship
> > > Â
> > "cc0919ship" wrote:
> > > > Hello all,
> > one.
> > the line.
> > > > Thanks,
> > > > Christian
OK, when the Poly goes directly into sequencer edit mode it usually indicates a problem with the chip select "Y4" signal getting through to the 3-11A signal. If you go to the files section and look in the Servicing section for the Poly-800. There's a zip file in there with the schematics. Look at the first schematic and in the upper right hand corner is the section that includes DTC5 and R135. That DTC and the resistor needs to be checked for proper functioning.
Mike
Sent: Thursday, January 24, 2013 9:55 AM
Christian
> Mike
>  From: cc0919ship
> Â
> > Don B.
> >   _____
> > Hey Michael,
> > > Mike
> > > From: cc0919ship
> > > Â
> > "cc0919ship" wrote:
> > > > Hello all,
> > one.
> > the line.
> > > > Thanks,
> > > > Christian
Re: Frozen Poly 800
I'll take a look when I get home in a couple hours, thanks!
> Mike
>  From: cc0919ship
> Â
> Christian
> > Mike
> >  From: cc0919ship
> > > Don B.
> > >   _____
> > > Hey Michael,
> > > > Mike
> > > > From: cc0919ship
> > > > Â
> > > "cc0919ship" wrote:
> > > > > Hello all,
> > > one.
> > > the line.
> > > > > Thanks,
> > > > > Christian
Compare the resistances across the three legs of DTC5 with two or three of the other DTC's. If there's a significant difference then you probably have found the cuplrit.
however, before you assume it is the DTC itself. Resolder the resistor and DTC legs. I've seen quite a few cold solder joints over the years. Resolder and see if you get lucky.
Mike
Christian
> Mike
>  From: cc0919ship
> Â
> > Don B.
> >   _____
> > Hey Michael,
> > > Mike
> > > From: cc0919ship
> > > Â
> > "cc0919ship" wrote:
> > > > Hello all,
> > one.
> > the line.
> > > > Thanks,
> > > > Christian
2013-01-24 by Jill Saphic
I'ts always amazing to me how some of you players just
pop up with this super techie,"deep inside the machine"
answers!
--- On Thu, 24/1/13, Michael Hawkins <korgpolyex800@...> wrote:
Subject: Re: [korgpolyex] Re: Frozen Poly 800
To: "korgpolyex@yahoogroups.com" <korgpolyex@yahoogroups.com>
Date: Thursday, 24 January, 2013, 15:18
Mike
Christian
> Mike
> From: cc0919ship
> Â
> > Don B.
> > _____
> > Hey Michael,
> > > Mike
> > > From: cc0919ship
> > > Â
> > "cc0919ship" wrote:
> > > > Hello all,
> > one.
> > the line.
> > > > Thanks,
> > > > Christian
You\u2019re forgetting that Mike Hawkins is the designer and builder of the Hawk-800 and AtomaHawk kits. If anybody has been \u201cdeep inside”, he\u2019s the one.
Don B.
From: korgpolyex@yahoogroups.com [mailto:korgpolyex@yahoogroups.com] On Behalf Of Jill Saphic
Sent: Thursday, January 24, 2013 10:43 AM
answers!
Mike
Christian
> Mike
> From: cc0919ship
> Â
> > Don B.
> > _____
> > Hey Michael,
> > > Mike
>; > > From: cc0919ship
> > > Ã\u201a
> > "cc0919ship" wrote:
> > > > Hello all,
> > one.
> > the line.
>; > > > Anyway, has anyone had a problem like this and could help me out? It is
> > > > Thanks,
> > > > Christian
Re: Frozen Poly 800
2013-01-24 by bimmerfan222
Mike, what is a DTC?  Is DTC5 used to cause an interrupt?
I was suspecting an error in or around their 3-8 chip..
Right now a dipclip with built in logic indicators sure would come in handy to aid in diagnosing their problems..
-Blaine
> Mike
>  From: cc0919ship
> Â
> Christian
> > Mike
> >  From: cc0919ship
> > > Don B.
> > >   _____
> > > Hey Michael,
> > > > Mike
> > > > From: cc0919ship
> > > > Â
> > > "cc0919ship" wrote:
> > > > > Hello all,
> > > one.
> > > the line.
> > > > > Thanks,
> > > > > Christian
Re: Frozen Poly 800
2013-01-25 by cc0919ship
Mike,
Just tested DTC5 and it is significantly higher (and shows resistance both ways) so it looks as though I may have found the culprit! I'm going to resolder it first as suggested.
Christian
> Mike
>  From: cc0919ship
> Â
> Christian
> > Mike
> >  From: cc0919ship
> > > Don B.
> > >   _____
> > > Hey Michael,
> > > > Mike
> > > > From: cc0919ship
> > > > Â
> > > "cc0919ship" wrote:
> > > > > Hello all,
> > > one.
> > > the line.
> > > > > Thanks,
> > > > > Christian
Re: Frozen Poly 800
I may have spoken too soon, in my haste it looks like I misread...now that it is out, it seems fine. Currently tracking down R135.
> Mike,
> Christian
> > Mike
> >  From: cc0919ship
> > Â
> > Christian
> > > Mike
> > >  From: cc0919ship
> > > > Don B.
> > > >   _____
> > > > Hey Michael,
> > > > > Mike
> > > > > From: cc0919ship
> > > > > Â
> > > > "cc0919ship" wrote:
> > > > > > Hello all,
> > > > one.
> > > > the line.
> > > > > > Thanks,
> > > > > > Christian
Re: Frozen Poly 800
Looks like in my haste I may have misread. After taking it out, it seems fine. Currently tracking down R135
> Mike,
> Christian
> > Mike
> >  From: cc0919ship
> > Â
> > Christian
> > > Mike
> > >  From: cc0919ship
> > > > Don B.
> > > >   _____
> > > > Hey Michael,
> > > > > Mike
> > > > > From: cc0919ship
> > > > > Â
> > > > "cc0919ship" wrote:
> > > > > > Hello all,
> > > > one.
> > > > the line.
> > > > > > Thanks,
> > > > > > Christian
Re: Frozen Poly 800
Tested R135, looks fine...hm...
> > Mike,
> > Christian
> > > Mike
> > >  From: cc0919ship
> > > Â
> > > Christian
> > > > Mike
> > > >  From: cc0919ship
> > > > > Don B.
> > > > >   _____
> > > > > Hey Michael,
> > > > > > Mike
> > > > > > From: cc0919ship
> > > > > > Â
> > > > > "cc0919ship" wrote:
> > > > > > > Hello all,
> > > > > one.
> > > > > the line.
> > > > > > > Thanks,
> > > > > > > Christian
Re: Frozen Poly 800
Sorry about all the posts, but it might be important to note that the display was the same even with the transistor removed
> Hello all,
> Thanks,
> Christian
2013-01-25 by Martin Ator
Have a real close look at any IC's with a magnifying glass and see if you spot any rusty legs on any chips especially around 80C55 80C85
Sent: Friday, 25 January 2013, 3:38
> Hello all,
> Thanks,
> Christian
2013-01-25 by Michael Hawkins
I've seen the DTC's fail both on this forum and in working with some of my customers.
So swap DTC4 for DTC5. DTC4 is used for the "Step up" jack. So you can swap it and see if you get anywhere.
DTC stands for digital transistor something or other. They are essentially a transistor with a couple of bias resistors built into one package so that they act like a saturated transistor switch. There are DTC's out there now more commonly known as BRT's.
http://www.onsemi.com/PowerSolutions/product.do?id=DTC144TM3
http://www.onsemi.com/PowerSolutions/parametrics.do?id=799
Mike
Sent: Thursday, January 24, 2013 10:38 PM
> Hello all,
> Thanks,
> Christian
2013-01-26 by Michael Hawkins
If swapping the DTC fixes the sequencer enable problem but then stops the "Step Up" from working (difficult to test if you don't have a pedal). Then you need to find a replacement DTC.
If it doesn't fix the problem then you need to resolder all pins on IC33 and IC34. If that doesn't fix it then replace 74HC240 IC33 first. If that doesn't fix it then replace 74HC138 IC34.
I've seen the 74HC240 fail a few times. I have not seen the 74HC138 fail.
Mike
Sent: Friday, January 25, 2013 6:59 PM
Mike
> Hello all,
> Thanks,
> Christian
Re: Frozen Poly 800
2013-01-26 by cc0919ship
Tried everything, no dice...looks like it might be IC33. Ordering one now. Thanks
> Mike
>  From: Michael Hawkins
> Â
> Mike
>  From: cc0919ship
> Â
> > Hello all,
> > Thanks,
> > Christian
Re: Frozen Poly 800
2013-02-25 by silvereletellier
Hey everyone,
I'm glad this forum exists!
My poly800 just came up with this 1.8 50 01 screen...
cc0919ship could you tell me if replacing IC33 solved your problem?
I really don't want to sell it for parts... Hopefully it's just a chip that needs changing!
Please let me know
All the best
Silvere Letellier
> > Mike
> > Â
> > Mike
> >  From: cc0919ship
> > Â
> > > Hello all,
> > > Thanks,
> > > Christian
2013-02-25 by Gordon JC Pearce
On 25/02/13 21:08, silvereletellier wrote:
> Hey everyone,
And you *have* checked the sequencer switch, right?
Gordonjcp MM0YEQ
Re: Frozen Poly 800
2013-02-27 by silvereletellier
Not yet to be honest. By the sequencer switch do you mean the actual button switch or the electronic around it? I don't really know what is connected to what.
Could you help locating the possibly damaged part please?
Thanks a lot
Silvere
> > Hey everyone,
> Gordonjcp MM0YEQ
Re: Frozen Poly 800
2013-02-27 by cc0919ship
Hey!
Sorry for the belated post, been away and haven't been near email...it was relaxing :) I tried replacing IC33 and IC34, didn't do it for me though, so I may end up having to give up :( Hopefully you can get yours sorted out! If you look at some of the earlier replies on this thread these nice people talk about how to test the sequencer switch, as well as the DTCs. The sequencer switch isn't on the front panel, rather it is on the back.
Christian
--- In korgpolyex@yahoogroups.com, "silvereletellier" <silvereletellier@...> wrote:
> Thanks a lot
> Silvere
> > > Hey everyone,
> > Gordonjcp MM0YEQ
Re: Frozen Poly 800
Ok thanks I'm gonna try to follow the electronic path to the transistors and ICs and see if signals are right first... I keep you posted! Don't give up!!! :)
> Hey!
> Christian
> --- In korgpolyex@yahoogroups.com, "silvereletellier" <silvereletellier@> wrote:
> > Thanks a lot
> > Silvere
> > > > Hey everyone,
> > > Gordonjcp MM0YEQ
