The Logic Off Topic list
Re: [L-OT] Re: TL Audio 3051
2002-02-07 by Mark Lennox
Have you any recommendations? I dont have loads of money but I dont want to
be left with a unit I'm not happy with.
The TL 3051 will be so much better than any EQ I have access to right now so
I'm sure I'll be happy with it for a while at least. Why do you have
misgivings about the TLAudio stuff?
cheers
Mark Lennox
Technical Consultant
ENDUSER
Suite 40
Guinness Enterprise Centre
Taylors Lane
Dublin 8
Ireland
Tel: +353 1 4100 665
Fax: +353 1 4100 985
web: http://www.enduser.com
To: <logic-ot@yahoogroups.com>
Sent: Wednesday, February 06, 2002 10:06 PM
Subject: [L-OT] Re: TL Audio 3051
> --- In logic-ot@y..., "Mark Lennox" <mark@e...> wrote:
> > Hi,
> > I really need some advice for a prospective purchase - the TL
> Audio 3051,
> > dual valve parametric EQ. How would anybody rate it?
> here any problems with its use/sound  minor or otherwise?
> depends on budget. in this kind of mid range tl gear is ok.
> personally, having owned tl gear, id opt for a more cash intensive
> unit :-)
2002-02-07 by highlandsource
but I dont want to
to right now so
have
i cant really recommend anything at all without a large price tag!
im in one of those tricky spots where im used to (other peoples!)
high end units - ie pro studios. my misgivings actually apply
across the board - seeing a trusted engineer switch a mid priced
unit on, listen to it for three minutes, then immediately put it in the
cupboard tends to colour my view! like many i either cant afford
or cant justify some sexy esoteric high end unit...sigh :-)
i owned a tl unit once upon a time, i think the 5051? it worked
moderately well, if slightly noisy. i guess we cant ask much more
than that of a reasonably priced unit. if the 3051 is a step up from
what you can achieve now then id say go ahead - and hope that it
helps cause you immense wealth, at which point you'll be happy
to part with three grand for a very fine equaliser indeed!
andy
