Extra monitor on a PB G3 (pismo)
2002-08-19 by frfjellh
Hi, I just wonder if anyone out there has any experience with connecting an external monitor to a powerbook G3. I have made some tests with an Apple 17 inch set up beside my PB with the same resolution (1024 x 768) but did experience some chrashes to the system. Does connecting an external monitor drain considerably more cpu power from the system? Should I make any changes to the system folder (9.2.2 does have a lot of display related extensions...). Any other limits? Would I be able to add say a 1200 x 1024 monitor? (In addition to the built in). My PB is a pismo G3 500 mHz with 512Mb Ram, running 9.2.2. Logic 5.2, Pulsar II (x2) in a Magma chassis. Regards Frode Fjellheim
