The Logic Off Topic list
Re: [LUG] Re: [OT] good monitorspeakers?
2003-12-02 by HKC
I'm thinking about buying Genelec 1030A active, powered
monitorspeakers.
I\ufffdd say that comparing speakers that cost 3 or 4 times what a pair of 1030A
does is a bit unfair. I mean I\ufffdm sure that anyone would rather have a pair
of ADAM 2.5 but they cost almost 4000 $. Within the same price bracket of
the Genelecs there are a lot of alternatives like Event, Mackie, Dynaudio,
Blue Sky and there doesn\ufffdt seem to be a winner here, they\ufffdre all good (or
bad depending on what you\ufffdre after). In the end all that matters is that
what you think sounds good in your studio also sounds good and pretty much
the same outside of it. Personally I think that any of these will do as long
as you also have an alternate pair of speakers like ie the horrible sounding
NS10s, there\ufffds a lot of truth in the line "if it sounds good on them it will
sound good on anything". One thing that also complicates this topic is that
unless you have a well acoustically adjusted room you\ufffdre probably better off
buying speakers especially for your room and not listen too much to anybody
else. If you\ufffdre mixes tend to be a little heavy in the low end, buy speakers
with not so enhanced low ends and vice versa.
Just my \ufffd cent
HKC
2003-12-03 by markdvc2002
> monitorspeakers.
pretty much
Yes, I think this is adressing one of the real secrets to finding the
right pair of speakers to mix on - the mixes have to translate to
other systems in other rooms. Therefore, it is really important to
know the strengths and weaknesses of your speaker/room combination,
to vary volume when mixing, walk around your control room - they all
have peaks and dips, and the smaller the control room, the greater
the difficulties in the bass end - indeed, the smaller control rooms
can have modal problems extending right out of the bass end into
frequency areas which can affect vocals. No matter what set of
speakers you choose, you have to get to know them REALLY WELL before
you can trust yourself to mix other peoples music on them. Me?
Genelec 1031 + 1092 sub, for about the last 10 years ....and I would
be very tempted to get a set of 5 1030's for surround .....ah well,
one can dream ....
kind regards
Mark Cahill
