The Logic Off Topic list
Normalize Vs Gain
Normalize Vs Gain
2004-03-12 by drummerboy5142
Like to end this argument once and for all. Is using the gain function
in the audio window better than normalizing your individual audio
tracks to bring the levels up to get the best quality recording to mix
with?
Drummerboy
Re: [L-OT] Normalize Vs Gain
2004-03-12 by amgshaffer
>with?
Normalization and Gain are similar functions.  Normalization just
maximizes the gain, whereas gain enables you to make incremental
adjustments (both increases and decreases).
However, John Pitcairn posted an interesting comment on using Logic's
normalization function (which I assume also applies to the Gain
function).  Here is a snippet of that post:
>The reason normalization is frowned upon is that it's generally
>performed at a fixed bit-depth as a destructive process - this will
>permanently reduce the sound quality of the audio slightly, due to
>resampling quantization error. Emagic do not specify the processing
>bit depth for the Sample Editor, but it may in fact be done at the bit
>depth of the original file (16- or 24-bit fixed point), which is
>definitely a bad thing.
>In Logic, it is far preferable to increase level by boosting the fader
>level and/or inserting Gainer plugins, which ensures that the increase
>in level is done both non-destructively and at a much more accurate
>32-bit floating point resolution. The result when added up across many
> tracks is _clearly_ superior to normalizing all the audio.
Given the above comment, I would assume the best way to maximize your
signal-to-noise ratio is get the levels set correctly when you record
the sound.  Otherwise, gain, normalization, or using the Gainer plugin
will raise both signal and noise.
Kind regards,
Dave
2004-03-12 by Hendrik Jan Veenstra
>with?
The best way (except for recording at decent levels :) is to use the
Gainer plug-in.  Since it's a plug-in, it operates in Logic's native
32-bit space.  All destructive edits, such as normalizing, work on a
24-bit level and introduce quantization errors (noise).
I don't think you get the gist of John's argument.  John explicitely
says that using a Gainer plug-in is preferable to normalizing in the
sample editor.  Saying that "they all raise signal and noise" misses
the point, which is that anything done at 24 bits introduces more
noise than when done at 32 bit.
Another but somewhat related argument against normalization:
normalizing is imo as pointless as the digital zoom on digital
cameras is.  If sufficient data is absent, the camera (Logic) can't
invent it out of the blue.  With a 200 x 300 array, you can't make a
_real_ 400 x 600 photo.  Likewise, if you have a recording that uses
21 bits of dynamics, increasing that to 24 bits (normalizing by
multiplying everything by 8) won't _really_ increase the resolution
of your recording by a factor of 8.  If you then realise that it's
not only pointless, but adds noise to boot, well... you get the
picture.
Hendrik Jan Veenstra   h @ k n o w a r e . n l
Omega Art: http://www.omega-art.com/
2004-03-13 by amgshaffer
I am actually referring to another point John made in his post....namely:
>Normalization doesn't affect the dynamic range of a signal, there will
>still be X dB difference between noisefloor and loudest peaks before
>and after normalization.
That is, normalization raises both the noise floor (as well as the
signal), but it also degrades the sound quality because it is a
destructive edit made at a bit depth of 16 or 24-bit which is certainly
introduces more quantization error than the 32-bit floating point
resolution of the Gainer and Normalization function.
Kind regards,
Dave
re: Normalize Vs Gain
2004-03-13 by mars@trinidad.net
> ** Original Message follows...
>    From: Hendrik Jan Veenstra <h@...>
> Subject: Re: Normalize Vs Gain
> >with?
> picture.
Good topic. Despite knowing this, I sometimes use the gain function to bring up a word or phrase or reduce a sharp peak that's preventing me from raising my average level. I really wish the Gainer plug-in had a finer resolution - at least .5dB steps. Also, the automation is still very fiddly - sometimes the display will not show you your level and you have to look at the info bar and compare numbers with earlier automation points. BTW, why is this OT?
Mars
[L-OT] re: Normalize Vs Gain
2004-03-13 by Hendrik Jan Veenstra
Yes, couldn't agree more (about the resolution, that is).  Holds for
the entire automation-stuff btw: why does the LC offer 10-bit
resolution while hyperdraw and environment faders are still limited
to this stupid stone-age 7-bit resolution?
Because we like a cosy small-scale chat amongst ourselves and would
rather not bother the LUG-masses complaining about delayed delivery
dates with sensible discussions :-).
re:Normalize Vs Gain
2004-03-14 by mars@trinidad.net
> Subject: re: Normalize Vs Gain
ffer 10-bit
:-) :-) Ah... it all makes sense now :-)
BTW, I can't remember if I ever responed to you, but both versions of Session Setup X worked fine - even under Panther.
Cheers
Mars
[L-OT] re:Normalize Vs Gain
2004-03-14 by Hendrik Jan Veenstra
Ah, wonderful!  No, you never responded -- and I forgot about it as
well :-).  So I suppose I can put it up for grabs then...  Thanks for
beta-testing.  Still I think I should try myself one of these days
(now that I've got an X-laptop).  I wondered (and forgot to ask you)
if the 'labels' stuff simply carries over from 9 into X.3 or if that
requries a new implementation (or omission -- whichever of the 2 is
easiest :-).
