The Logic Off Topic list
Re: [L-OT] Virtual PC & Midi & Vamp2
2004-04-06 by Sascha Franck
"Michael Scheurer" wrote:
> Ideally I'd love to get hold of an environment for the Vamp2 but my
> 'environmental' skills are not up to the task.
I just bought a Vamp 2 (great little thing, WAY WAY better than my good old
POD which will now gather dust) and one day I may build a little environment
for it, but I'm not sure when and if that will indeed happen. The PODs MIDI
implementation was so-so-ish, but the Vamp seems to be pretty much easier to
handle. I'll have at least a brief look at it over easter.
Problem with the existing POD environments over here allways was, that when
I did some "send all fader values", it never resulted in what it was
supposed to result in...
Sascha
2004-04-06 by Michael Scheurer
> good old POD which will now gather dust) and one day I may build a little
> environment for it, but I'm not sure when and if that will indeed happen.
> The PODs  MIDI implementation was so-so-ish, but the Vamp seems to be pretty
> much  easier to handle. I'll have at least a brief look at it over easter.
> when I did some "send all fader values", it never resulted in what it was
Found an environment at Swiftkick
<http://www.swiftkick.com/loglugother.html>.
Will have a play over Easter as well. Doesn't look like it does much in
the way of patch management.
michael
Re: [L-OT] Tool for Eliminating Vocals on a CD
2004-04-07 by mercutio
On Tuesday, April 6, 2004, at 10:23 PM, Chaz wrote:
> Can anyone suggest any software tools that take the
> vocals off of a song from a CD?
Don't look for something "fantastic" - it probably doesn't exist.
otherwise - "Amazing Slow Downer" does a decent job of suppressing
vocals in its karaoke mode...
2004-04-08 by dollenmayer
I am not aware of a plug in that can remove vocals that have not been
mixed right "down the middle" however a very effective plug-in is the
Analog X vocal remover, which is quite amazing.  MAGIX has an
inexpensive audio program that also has a Karoke setting.  to find
the analog x plug in check out this link.
http://www.directxfiles.com/manufacturers/analogx_voc.htm
