Hi Matthias,
My project is to design a new SDIO card dedicated to a professional
mobility application on PDA's. This card should work on any PDA brand
under any OS. Of course the SPI data transfer mode seems the simplest
way to use a "standard" micro instead of a dedicated SD/SDIO
controller (like C-Guys' CG100 or Arasan's AC21C00)
Unfortunately, it seems as if SPI is not always supported by the
device driver development kits on the host side. 1-bit and 4-bit
modes are always supported. It looks as if the SPI mode would getting
obsolete. Am I right ?
Regard,
Michel Kuenemann
--- In lpc2000@yahoogroups.com, Matthias Hertel
<matthias.hertel@w...> wrote:
> Is there a special reason, why you want to do this?
> Using the SPI does not consume that much CPU time, and is quite
fast.
> As long as you do not want to use SDIO cards, I see no real reason
using the
> SD specific transfer modes.
> Matthias
> On Thursday 03 November 2005 00:43, kukbelz wrote:
> > Dear LPC2000 group and Philips,
> > Keils's MCB2140 Eval. Board demonstrates the use of the LPC214x
as an
> > SD host controller.
> > On the other hand would it be possible to use the LPC214x as an
SD
> > device controller implementing SPI, 1-bit and 4-bit SD data
transfer
> > modes as they are defined in the SD Card specifications ?
> > In this case what level of performance (clock speed) is
achievable ?
> > Thank you.
> > Michel Kuenemann
> > YAHOO! GROUPS LINKS
> > Visit your group "lpc2000" on the web.
> > To unsubscribe from this group, send an email to:
> > lpc2000-unsubscribe@yahoogroups.com
> > Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
