jp_thrower wrote:
>The baud rate may be off by 1.7 %, however the PC still communicated
>correctly when I used the exact same baud rate, 117187, from other
>register configurations (as reported U1DLL= 0x02, 0x03).
I thought that the acceptable degree of error is somewhere around 0.5%?
1.7% seems to be very high...
Let's see, 2400 - 1.7% == 2359buad, nope, I would not expect that to
work! I've gotten errors while being as much as 10 points of at 2400,
e.g. 2390baud.
Where do you see that a 1.7% deviation is acceptable? It has been a
while since I've played with software uarts but I tried to keep within
0.25% of error.
TomW
>Furthermore, the behavior of the receiver not working when U1DLL=0x01
>is consistent with screwy behavior I got at 500000 baud. I reported
>on that in posting # 9985.
>I have worked around my issue by doubling the PCLK (it was going at
>1/4 CCLK) and using a U1DLL=0x02. In this particular case it doesn't
>seem to cause too many additional issues. Regardless, the phenomenon
>seems like an error in intended operation.
>JP
>--- In lpc2000@yahoogroups.com, "rtstofer" <rstofer@p...> wrote:
>>You baud rate error is on the order of 1.7%. That the PC will
>>accept it is to its credit. That the LPC won't is not a surprise.
>>Assuming your PCLK is as accurate as you hope - have you checked it
>>with a frequency counter?
>>The examples in the user manual have errors around 0.06%
>>Further, you may not be sending EXACTLY 115200 from the PC.
>>This is not to say I have any idea about how to resolve the issue.
>>I just noted the huge difference in % error versus the user manual.
>>Richard
>>--- In lpc2000@yahoogroups.com, "jp_thrower" <jp_thrower@y...> wrote:
>>>This post is a followup to my original post number 9985.
>>>When U1DLL = 0x01, U1DLM=0x00, and is used with the fractional
>>divisor
>>>U1FDR to set the baudrate, the device properly transmits at the
>>>assigned baudrate, but does not receive at the assigned baudrate.
>>>I have conducted a series of elementary tests using the frequency
>>>117187 and a PC com port terminal set to 115200 baud. The program
>>>(genesis from Keil's example to give credit) transmits characters
>>from
>>>the LPC2148 to the PC, reads characters from the PC, and echos them
>>>back to the PC.
>>>The frequency 117187 can be acquired with multiple settings using
>>a 12
>>>MHz clock, or 15 MHz PCLK:
>>>UART_baudrate = PCLK/(16*(16*U1DLM+U1DLL)) * (MulVal/
>>(MulVal+DivAddVal))
>>>U1DLL, MulVal, DivAddVal, Equation
>>>0x01 0x1 0x7 117187 = 15000000/16/(1)*(1/8)
>>>0x02 0x1 0x3 117187 = 15000000/16/(2)*(1/4)
>>>0x03 0x9 0xF 117187 = 15000000/16/(3)*(9/24)
>>>In each case, the tranmit of characters worked fine, but in the
>>case
>>>of 0x01, the receive characters were garbled.
>>>I do have set U1FCR |= 0x01, which the manual says is required for
>>>correct operation.
>>>Is there an errata on this? Does UART0 have the same issue?
>>>Is there a way around this that I don't know?
>>>This is important to me because I have to work with 500000 baud
>>>signal, and U1DLL=1 seems like my only option without swapping
>>crystals.
>>>JP
>Yahoo! Groups Links
