haha......that was one of the problems. The other one was the bit
timing....I hate CAN bittiming. I understand it but still hate it!!!
I don't know how biginners can do CAN :-)
Gus
--- In lpc2000@yahoogroups.com, "Gromann, Klaus"
<klaus.gromann@r...> wrote:
> Hi Gus,
> Bit0 of the AFMR-register turns off all CAN messages, that means
all
> messages are ignored.
> If you want to receive all messages you have to set only bit1 of
> AFMR to 1
> AFMR = 2 should do what you want
> brgds
> Klaus
> From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com] On
Behalf
> Of Gus
> Sent: Tuesday, November 01, 2005 7:32 PM
> To: lpc2000@yahoogroups.com
> Subject: [lpc2000] simplest CAN test!
> For a starter, I just need to get the CAN module going in LPC to
> just ACK the frames back!
> Can anyone tell me what I am doing wrong?
> Is it correct that when AFMR=3 I will get all frames? If not, how
do
> I get all frames? I don't need filters enabled!
> My chip is not sending any ACK or error frames at all!
> //500kbs @ 16Mhz
> #define PROB 1
> #define BRP (1-1)
> #define SJW (1-1)
> #define TSEG1 (8-1+PROB) //including propagation
> #define TSEG2 (6-1)
> #define SAM 0 //sample once
> void CANtest()
> C1MOD=1;//reset CAN
> // set the pin to CAN 1 RD1 (TD1 is not mult.)
> PINSEL1=PINSEL1 | (1<<18);
> AFMR=3;
> // set bit timing
> C1BTR=BRP|(SJW<<14)|(TSEG1<<16)|(TSEG2<<20)|(SAM<<23);
> // enable CAN
> C1MOD=0;
> while(1);
> Gus
