Lpc2000
LPC2131 wont run .hex file
2005-11-03 by nealbrains
I am using LPC2131 dev board from new micros, and am trying to get some
of the hex file examples to run, but I am running into problems.  I am
trying their hello.hex example which prints hello over and over again
on a terminal window (I am using NMITerm).
  I upload the hex file through LPC 2000 flash utility and everything
loads fine but when i open NMITerm and setup all the settings nothing
happens.
  Also I tried the blinky.hex example which makes the chips LEDs
flash.  when i load the hex file on it doesn't start flashing.
What could be the problem?  bad serial cable?  LPC2000 flash utility
reads the board ID though.
neal dyrkacz
