Lpc2000
I2C problems with LPC2138 + GNU + I2C.1+Keil board 2130
2005-11-06 by Ake Hedman, eurosource
I wounder if someone have experienced problems with the second I2C
channel on the LPC2138 chip?
I am trying to interface a 24LC512 chip. I can write to the chip OK (I
believe so anyway as the correct states are gone true) but  read always
return 0.  The zero return can be maybe be due to other things but  the
real problem is a read when the code arrive at state 0x50 and I want to
do STOP condition . If I write 0x10 to the I21CONSET register the board
dies. The only way to wake it up again is to toggle power. Reset would
not wake it up.
In my first attempts I wrote the data using a pointer and though the
pointer was the problem but after replacing it with a static location I
experience the same problems.
Any suggestions welcome.
Cheers
/Ake
Ake Hedman (YAP - Yet Another Programmer)
eurosource, Brattbergavägen 17, 820 50 LOS, Sweden
Phone: (46) 657 413430 Cellular: (46) 73 84 84 102
Company home: http://www.eurosource.se
Kryddor/Te/Kaffe: http://www.brattberg.com
Personal homepage: http://www.eurosource.se/akhe
Automated home: http://www.vscp.org
