Lpc2000
P0.31 during reset clarification
2005-11-07 by Bhanu Nagendra Pisupati
>We had pulled P0.31 down because it was the enable for a 485
>transciever and needed to be low during reset.
>Turns out there is an 'undocumented feature' on some of the LPC
>parts including the 2138 that will disable JTAG if P0.31 is low during
>reset. We all know about RTCLK needing to be high during reset
>for JTAG because it's documented, but P0.31 functions exactly the
>same way.
I am not sure as to how one can guarantee that P0.31 is indeed pulled high
during reset to enable JTAG debugging. I assume this would have to be done
in software running on the device, but then to get that software into
memory requires use of the JTAG port. Seems like a chicken and egg
problem. Am I missing something?
-BNP
Re: [lpc2000] P0.31 during reset clarification
2005-11-07 by Bill Knight
>>same way.
>Thanks,
>-BNP
Put a pull-up resistor on the pin.  It's configured as an input as the
processor comes out of reset.  You can set it to being an output pulled
low in your startup code.  A better solution would be to move the functionality
to a different pin then it wouldn't hog the 485 bus every time the system was
reset.
-Bill Knight
R O SoftWare &
http://www.theARMPatch.com
Re: P0.31 during reset clarification
2005-11-07 by Gus
What chips does this apply to?
Gus
during
> >>same way.
pulled high
to be done
into
> >Thanks,
> >-BNP
pulled
functionality
system was
> reset.
> Regards
> -Bill Knight
> R O SoftWare &
