Lpc2000
JTAG Wigggler vs. IO012 problem
2005-11-06 by Boris Kralik
Hi all.
I have a one problem, please help me to solve it.
In my hardware I build JTAG EI012 interface
http://www.geocities.com/kralikbo/EI012.pdf . This interface is same
as Wiggler, only pins are connected to other contact on parallel port.
EI012   - TRST:D4   , TDO:BUSY , TCK:D0 , TDI:D1 , TMS:D2
WIGGLER - TRST:nRST , TDO:BUSY , TCK:D2 , TDI:D3 , TMS:D1
I have TRST signal connected to nTRST, no to nRST. It is not cardinal
different I think, is't it ?
When I try IDCODE command "detect" in jtag-tools
(http://openwince.sourceforge.net/jtag),  command works
fine, other command works fine too (EI012 interface). When I
reconfigure interface to
wiggler, jtag not works. Next I check all pins wiggler interface and
check processor jtag pins:configure pins TCK, TDI, TRST, TMS as input,
sent to LPT port values 4, 8, 1, 2 and redirect GPIO1_IOPIN value
(http://www.geocities.com/kralikbo/Jtag.tar.gz) to UART0 and look on
terminal (lpc2k_pgm) = all jtag pins works fine. Next i check TDO pin,
it works fine also.
I try it with JTAGER-0.3.0, jtag not work, I try to reset jtag using
reset command, I saw impulse on TRST = all port pins work fine (I
check it preliminarily) = hardware is OK.
Do you have any suggestions, where may be a problem ?
Thank you for any ideas.
btw: I configured pins P1.26:P1.31 (PCB_PINSEL2	|= (1 << 2);) as jtag
port.
Re: [lpc2000] JTAG Wigggler vs. IO012 problem
2005-11-07 by Boris Králik
I solve the problem.
Routine for EI012 cable work with slow rate, big
delays. I have TDI pin conneced to second part
74HC367, other pins are connected to first part.
Wiggler routine is faster as EI012 (I don't know why),
therefore TDI has lower delays as EI012 cable; this
was main problem, in delays. When I test it in parts,
it works, becouse low rate and delay don't do
fundamental thing. When I connect TDI, TRST, TCK, TMS
to first part and TDO to second part, it works fine,
all signals have same rate and delay.
BorisK
btw: Be carefully, when you make JTAG interface, what
parts you select.
--- Boris Kralik <kralikbo@...> wrote:
> Hi all.
> interface is same
> on parallel port.
> TMS:D2
> TMS:D1
> It is not cardinal
> works
> interface). When I
> TRST, TMS as input,
> GPIO1_IOPIN value
> UART0 and look on
> it works fine also.
> reset jtag using
> work fine (I
> (1 << 2);) as jtag
> port.
Regards / S pozdravom Boris Kralik
___________________________________________________________
How much free photo storage do you get? Store your holiday
snaps for FREE with Yahoo! Photos http://uk.photos.yahoo.com
